got a question for ya's
i have a type 4 daughter board in my r34.
I know that the daughter board has its own EEPROM that we can change the values in while tuning in nistune software. And the original ECU's EEPROM stays unchanged, we just tell the ECU to read from our new EEPROM. Is this correct?
If this is correct, could i tune my car on pump fuel 98, then take the hex file from the daughter board's EEPROM and burn it into the original ECU's EEPROM, then re-tune the daughter board as usual on e85 fuel? then i just have to run a couple of switch wires from the jumper pins on the original ECU to the dash and i have instant capability to drive on either fuel.
But is it even possible to burn a new image into the original ECU?
and can anyone see any major flaws in my idea?
Nah that wouldn't work, Just have the laptop handy.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5176763
Are the daughterboards for 32GTSt and 32GTR the same?
Reason I am asking is I am looking at Nistuning my 32gtst but if I max out my z32 afm, I am wondering if I can swap the daughterboard in to a 32GTR ECU and get a GTR image loaded on there ? (and then run a GTR engine harness and twin afm's)
use a ford lighting maf.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5177314
  • 3 weeks later...
If the resistance is correct they will,If you go low impedance you need resistor.
Yeah they're low impedence and I'm aware of needing resistors but was just flicking through the Nistune website and it mentioned 800cc's being about the limit.. :cool:
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5208419
What Fuel are you using? Petrol is a bit tough but can be done, E85 with those injectors is easy.
Yeah petrol for now, only looking for 500rwhp but later down the track (after I have put some more pumping power into the fuel system) I was thinking about E85 for track days.
Just wasn't sure whether it was a timing restriction or something that limited you to 800cc..
My setup is:
RB30DET (R32 RB25DE head)
Stock DE cams
GT35R (0.82 exh)
6boob mani
50mm progate
1000cc Rochester inj.
Stock rail and reg (hopefully)
1x 044 in tank
z32 afm (for now, until it maxes)
Will Nistune be able to run this setup nicely? Basically trying to decide whether to sell my Haltech and Nistune it, or keep the Haltech.
It's my track toy so the Haltech has some nice features (rotational idle would be cool) but they're not really needed, could sell it and utilise the money elsewhere..
Cheers for the help!
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5209880
If I was starting from scratch Id have saved the coin and used Nistune but as you have the Haltech Id keep it. Im using Platinums in most racecars now but the E11s are still very good. 1000cc injectors are good for well over 500rwhp with E85 so its only the delivery that would need updating.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5210140
Question.
I have r33 gts.
Mods: r34 cooler, hi flow turbo, splitfire coil pack, exhaust, pod, turbotech T boost controller.
How much would it approximately cost $$$$ to get nistune and approx $$$ to get it tuned in Victoria? Just rough estimate what i need so i know if its worth it.
Im running MINES ecu but if its worth it, might upgrade.
Thanx in advance.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5210963
The Haltech came with my Stagea (which will be getting Nistuned soon so VCT and the auto work properly) so I have a bit of flexability there and I guess a couple of extra 044's and a surge tank would be the go when it comes E85 time.
Cheers for the advice! :P
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5211293
Question.
I have r33 gts.
How much would it approximately cost $$ to get nistune and approx $$ to get it tuned in Victoria? Just rough estimate what i need so i know if its worth it.
Thanx in advance.
A full tune including installation of the nistune unit would set you back around $800 I imagine, your mods aren't too extreme so they could start with a base map and go from there saving on tuning time. I'm sure you could get it cheaper but with tuning cheaper does not mean better, you are almost always better off spending the extra at a reputable tuner who does nistune ECUs regularly.
I think Dr. Drift in VIC is meant to be one of the better tuners for nistune, though anyone feel free to correct me.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5211354
Don't know if you saw Evans, (Quiet achiever on here) DR30 Racecar? Runs 1000cc and 2 044s on E85, makes 620rwhp with more left but the class runs 7inch radials so we could not use the power. 61sec laps on the long track. So 2x 044s will do you fine
Oh very nice :P
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5211459
Question.
I have r33 gts.
Thanx in advance.
Get a decent cooler before an ecu remap, the r34 cooler is not much better than std.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5211713
Hi!
I wouldn't say that the R34SMIC is not much better.
It's clearly not as big as a FMIC but depending on your setup it's a good alternative to the standard R33 SMIC.
R34 vs R33
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5212421
Not everyone wants to run a front mount (police), but thank you for your input, even tho that's not what i was asking...
Edited by adis
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5212477
Thanks for that.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5212480
Hi!
R34 vs R33
Why? its junk unless you drive like a 100yo or run std boost. we have tested them over and over for stubborn people who were told online they were a decent upgrade.... they arent. A decent return flow front mount cooler (no cop issues) will allow just about unlimited hard driving before heat soak occurs.... the r34 one needs little more than half a lap or a few spirited runs in the hills before its transformed into a inter warmer.
https://www.sau.com.au/forums/topic/181930-nistune/page/12/#findComment-5212931
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
