  • Replies 90
Posted Images
Well, its a Top Secret GTR style front bar if any one is questioning the title.
and after:gallery_23968_1957_67861.jpg
Tell me which look do you like better :P
Just a teaser more pictures to come.
:ermm:
Ive been eagerly awaiting ur results Forged, its finally here. Wooo... Looks mint mate. Did u end up using Impul skirts? Which rear bar did u go with or r u still deciding on that one? Im leaning towards the GTR rear atm.
If its not too much to ask, can u get me a few more pics of both front bar & Impul skirts from different angles? As u know this was exactly the kit i was gonna be going with, was just awaiting ur results. Lemme know how the fitting went and also quality of the kit.
Thanks for all compliments. Yeah I thought its gonna be quite an unique package. Glad it turned out the way I imagined :cheers:
2nd one is easily better.
I like the more open grille and of course the big mouth FMIC.
What rims are those?
Thanks G Force. Yeah had a few delays putting parts together so it took longer than usual but it was worth the wait I think. Yes these are Impul skirts. Good to know that you are thinking along the same line here, I really do prefer the simple look of the Impuls that IMO flow better with the car's original bodywork. Still has the standard rear bar at the moment. Not sure if I want to change it. Maybe you guys can give me some ideas.
I will have some more pictures soon, might be doing a photoshoot the during the weekend.
Nice, very nice indeed
I do agree with DriftyR33 though in that gettin a lip on there would finish it up nicely, but well done
The bottom lip for the Top Secret front bar is not available for a Gt-t, not that i know of anyway. Im chasing one myself. U can get a genuine Top Secret CF one available only for a Top Secret GTR but it would cost u an arm n ur left nut. The next best idea i could come up with was to get someone to make this lip up, no idea how much it would cost tho and im thinking it'd probly be better made of plastic rather than fibreglass since its at the bottom & may need to take abit of a beating from the speed humps & kerbs.
Anyone have experience with moulding kits or had one custom made for them? Would like to hear ur thoughts on this and the cost involved.
Hey Forged not trying to hijack ur thread but thought u may be interested in this as well.
i was quite interested what the car would look like with a nismo style bonnet lip. must of cost you a fortune for that thing from powerplay imports.
but does look insane mate
can we get some front on views?
Edited by R34NRG
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
