Ok so this problem started occuring a few days ago, then went away. This morning when i left for uni it was happening for the first bit, but seemed to sort itself out as i got going, but when i came home this afternoon it was doing it all the way home.
The problem: Car majorly struggles to even accerate normally. Any attempt to accelerate results in bad missing, surging and jerking. At times I was struggling to maintain 100km/hr. At Idle the revs fluctuate majorly from a few hundred (almost stalling) to ~1500. Car actually did stall on me when i had the clutch in. Car would probably stall if i left it but i obviously try and keep it going by pumping accel. A/F guage is showing car running rich, even under incredibly light acceleration (5% throttle according to SAFC). AFR's in the 12's and 13's at idle, dropping to 10's and 9's when i try and accelerate (even under light accel). Nothing has changed about the car in the past couple of months.
other relevant car details:
Splitfire coilpacks
Iridium spark plugs, 6 heat range gapped @ 0.8
AFM was replaced with 2nd hand one about 4 months ago after the old one was playing up.
o2sensor seems to be working fine based on the sensor output on my apexi pen turbo timer. (and afaik wouldnt cause problems this severe anyway).
Car runs 8psi boost most of the time, with the occaisional fling of 12psi.
If you need to know anything else, post and ill supply info if i can.
The thingsI've come up with is:
- a possible leak in the i/c piping ? I dont know how or why this would have happened apart from hitting some bumps and jolting it loose. I took a really quick look and couldnt see anything obvious. I'll take a better look tomorrow in better light.
- afm playing up again
- something much much worse =\
help would be appreciated.
https://www.sau.com.au/forums/topic/182064-pretty-major-problem/
  • Replies 42
when i had a leak in my rb25det cooler piping, it still ran fine off boost. never took it past 80km/h but it was fine at that speed. its fairly easy to check with some detergent and a air compressor
impossible for ur car to run fine with a large leak in the piping.
Basically what happens is the AFM takes a reading of the air coming in, tells the ECU. The ECU then detirmines how much fuel u need based on this reading. If the air subsequently leaks out, it never gets to the engine so u will run very rich, which will cause the engine to drown and hence stall.
AFM, Cooler Piping or maybe a leaky BOV
I have had this happen twice to my car, Leaky piping was not as major as the AFM and I wasnt stalling much just crappy behavior down low, but the AFM caused all sorts of stalling and inability to start the car!
yea im leaning towards piping because when i check the SAFC Sensor Chk page, the AFM volts seem about right. or at least i think they are right - 1.2ish volts at idle, 2-2.5 under light throttle, 3 when i started to push it a bit. Will go over the pipes as best as i can tomorrow morning and if i cant find anything, will take it down to slide/murnane.
fuel pressure test was carried out a few months ago came back AOK. To add a twist, i took the car for a drive just then and it drove perfectly =\. Next time it happens, ill check AFM voltage. That should clue me in as to whether or not its the AFM or a leak... or something else :P
sup strik3r
can you graph your afm voltage?
makes it much easier to catch it misbehaving
i just had to deal with a afm playing silly buggers (when it felt like it)
was a pain in the arse and difficult to diagnose
what does a fuel pressure test done a few months ago have to do with a possible dieing fuel pump today?
nothing i guess. but if the fuel pump was dying, wouldnt the mixture be lean and not rediculously rich ? Bosch 040 pump. Been in the car for a few years. Can still here normal fuel pump noise at idle.
sup strik3r
hi spooky :rolleyes:
not easily.. im just running a poor ol SAFC2. I can get a 30 second window, but thats about it. will try and pay more attention next time its playing up (or get the passenger to do so).
when its playing up. unplug the airflow meter and see if there is any change. sounds like afm or the plug to it. does it backfire thru the intake?
doable, although my AFM is in a cold air box, but i can open her up easily enough. Im not exactly sure what you mean by backfire through the intake.. shoot air back out the filter ? i dont think it is.. although i have no sure way of knowing. Nothing sounds abnormal except the exhaust popping and farting a bit from the extra fuel. if i end up finding the AFM at fault, i swear to god im tracking down a MAP based ECU. sick of stupid AFM's screwing up.
forget the turbo timer reading, i got one, and a wide band o2 sensor and the timer a/f reading is so far off the mark its not funny. another thing to check would be to make sure your throttle on/off switch is switching. also you say you have a safc, has anyone been playing with it and accidently changed one of your afm in or out settings or type of afm it is.
nah no one would have touched it, but i will double check that. i know the turbo timer reading isnt worth much, but when all was working fine, it actually seemed to be relatively close to the mark - 14.2 - 14.9 while cruising and as soon as you start pushing it it dropped to 11.5-12 which is about spot on where the tune is. Even if it was wrong then, just the difference in what its reading now indicates a lot more fuel / richer mixtures. Will update with any info i find out tomorrow morning when i have a chance to give it a good look over.
thanks for the input so far guys !
hmm well, its been raining this morning, so havent had much of a chance to examine much, but when it did briefly stop, i went over most of the piping looking for anything loose - didnt find anything. Also took it for a drive and the car behaved perfectly =\ will monitor and update if i notice it again.
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
