I dont think a R33 snorkel will well as thats more for sucking air from the outside in, as opposed to ramming air from the outside in, hence you'd need to build some sort of sealed box around your pods and then have the snorkel running to the front just under the bonnet.
Could try a funnel and pipe from the front bar, through the left hand guard and to the pods. (i have something for sale in my signature, sorry shameful plug here hahaha)
Alternatively, have a vent in your bonnet installed above the filters? looks kinda crapping though.
Or have a vent on the bonnet closer to the back of the engine bay on the passenger side, R34 GTR VSpec style to draw away hot air?
I hate it when people you know from work find you on internet forums that you shouldn't be using... at work.
Gotta go to Kemerton for a dull meeting. Will try & catch up later.
All for good OH&S practices.
Call it a de-stress.
You know you do your stretching and eye exercises and surfing .....
lol
well we have standard on the race car and will go headlight intake on the track car once we get to that.
Its a lot of work, but what about relocating the oil cooler? Can it fit on the other side? Ours live where the air con used to sit leaving plenty of space for intake
For me it is more important that the air be cold than I get every last bit of pressure gain from infront of the car.
A pod box (not really, but a plate between them & the remainder of the engine bay) is on the agenda, but it is difficult to fabricate because of the 2 afms, power steer reservoir & all the other crap Nissan saw fit to jam in there. You can't find room for a 100mm duct (the requisite size) if it is round - hence the over the radiator preference.
And, no I am not going to hack holes in the bonnet.
Actually, as to your last point there is a high pressure area at the base of the windscreen. It is common for cars (Mostly track cars) to take their air from exactly this position. Check the old Brock VL Commodores for but one example.
This is what i came up with having some left over flexible ducting, and having my oil cooler towards the centre right side of the car. Ran the ducting from the right lower side up to and behind the left head light, held on with cable ties.
Have also seen ones like the tomei ones that feed direct air to the pods but also having a headlight positioned in the same spot N1 headlights.
edit found that headlight intake bit...its from nengun, prob only for race use???? http://www.nengun.com/silk-road/section-headlight-intake
no room at all to run anything from the n1 vent unless you cut a hole through the intercooler core as the back of it just about touches the intercooler.
Yeah I was hoping that there would be enough room to mount a smaller version (It is possible I have fewer hp than the Saurus Gt-R) above the radiator support crossmenber thingo. The bling cooling panel should stuff enough air into the general area, just a case of getting enough cross section for the duct immediately above the radiator.
Maybe if I just unbolted the one from my Falcon & used that as a start point.....
Edited by djr81
lol, I know, I've spent a fair bit of time crawling all over that car!
next time I see hayahi-san I should ask him to make us up one for GTRs that want to keep front mounted rad, and air con. :D
i guess with a custom rad from PWR or the like, and then find an air con core from another model that is shorter it could be done. :(
Well some bloke called Fred (apparently not on these forums) did it this way. Maybe that is the proper or even only solution. Would mean extensive hacking of the radiator, but looks doable.
I have seen pics where "fred" lowered the radiator about the same amount to fit his CAI
djr81
After looking at my car (and now thinking out loud) it may be possible to link up the air deflector/guide with the std snorkel. If you made a new snorkel to take in the std position and bring it forward of the radiator cap/raised section of the radiator there looks like there may be enough room to get a full grill width intake slot using the air guide as the base. A bit like the Saurus one but further forward.
I'll see if I can mock something up over the weekend or give me a yell and go over it.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
