well i drive a R32 1992 Nissan gts-t i got a problem with my skyline and i want to see if anyone can point me in the right directions.
the car just dies on me when slowing down after a boost. for example in main street got speed bumps inbetween everyone boosts it, so other day i took out and i boosted it and then had to slow down for speed bump. Wasnt going fast around 50 probably less. so you let foot of accelerator to put on break, but the car dies on me. is it bcos i let my foot off to fast??
how can i stop that happening as its embarrising lol
https://www.sau.com.au/forums/topic/183071-skyline-cutting-out/
if everyone jumped off a bridge would you jump off too?
does your car have a different blow off valve (bov) than the standard one?
that is the usual problem of stalling when coming to a stop/low revs etc.
to fix it, you need a plumback bov.
if none of this makes sense, take a pic of your engine bacy and post it here..
Doctor, it hurts when I do
this ...
It's probably a problem with the AAC valve can't react fast enough to open the air way for idle control.
Don't boost it - waste of time and energy... and fuel
if its actually cutting out (as in dies completely rather than loses revs) then its your AFM, do a search for "+solder +AFM" to see how to fix it
Thats not always true, mine was stalling, put the standard bov back on and hav'nt had a problem since.
if you re-read my post you will see that i was referring the AFM fix to "cutting out" rather than "stalling",
99% of the time true "stalling" is related to BOV venting to atmosphere
Edited by WazR32GTSt
  • 3 weeks later...
The problem got really bad n my car today, could'nt even hold 100k's on the freeway, only thing i had done was fitting an airbox, i changed the afm over to a spare i have and i now have no more problems.
the only part i could see that could be opened on the old afm was where the plug is, took the screws out and gave it a wiggle and it came out, virtually no resistance considering there is 3 pins on there that should have been securely soldered inside.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
