Gday,
On my r33 gtst I've worn my right front inside shoulder down bare. I'm guessing I've got too much neg camber on this front wheel. Left front is heading down the same path.
How is the camber adjusted on an r33, is it adjustable without buying an aftermarket camber pin kit? Or is this more to do with alignment? The car itself tracks straight, hence i'm guessing camber problems.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/
I like the standard camber angle and would leave it alone. if you adjust it for best tyre wear the car will handle like sh1t. Just take the tyres off and swap them over so they wear on the other side. my falken's wore badly like this. i've had bridgestone s03's now for about 10,000km and havent flipped the fronts yet and they dont even look like wearing unevenly.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382516
I dont know about rotating for better wear. A lot of performance tyres are directional. I'd recommend the camber adjustment kit or an extension on the standard adjustment. Whether it will handle like shit or not depends if you are racing. For street, I can tell you it makes no difference to handling....how do I know?....cos I had all four of my wheels camber adjusted back in for wear reasons. Go to a reputable suspension mob for quality advice RB25 my good man!
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382537
you can still swap side with directional tyres, you just need to have them rotated on the rim at the same time (so they point the other way).
And i'd check both camber and toe-in, it can probably be adjusted within the factory adjustment without needing a kit.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382564
guys - in my post i said to take the tyres off the rims. so what you do is leave the rims on the car and swap tyres keeping them pointed in the proper direction. this will wear them on the other side. trust me - i do it all the time.
and no - you cant rotate directional tyres. i do this coz i have 235 on the front and 275 on the back....
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382659
i was telling my mate to do this just yesterday
i didnt think some one would think this was as well
just goes 2 show that great minds think alike :D
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382715
RB25.....fair cop, I agree you could swap the tyres. But I think the best would be to sort the prob out once and for all ?? Each to his own....I just couldn't be stuffed rooting around every couple of months swapping tyres. My tyres were wearing out on the inner side down to bald at around 6-8 months. That would mean, after swapping, I would still only get 12-16 months out of a set of fronts...maybe a tad longer on the rear. Now I have the problem sorted, I've seen diddly squat wear on front or back....no stuffin around...no change in handling.
Just my experience.
cheers Ozzy
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382779
Not enough negative camber. Same as my car, got kmac strut tops and still cant get enough. Grrrrr.
If you have your car set up for good front end grip under spirited driving with some decent negative camber, it will wear the inside edge if you just drive around sedately.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-385029
350z's wrx's and hsv's are common victims :) I love to chop blokes in their R8's. they think theyre unbeatble in thier heaps of sh1t. i like to sh1t stir em at the next set of lights --  whats wrong with you car mate? why cant your big v8 beat my jap crap 2.5litre 6?   I dont even bother racing these morons anymore - i just rev the skyrine @ the lights, let em drop the clutch and then i putter off like nanna.
let the whoring end.....
hahahahahhaaa I LOVE IT!!!!
hahaha!!! I am not alone :)
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-396355
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
