hi guys,looking for a screamer pipe for my r33,if any one has one or who knows anyone that makes them in perth.my turbo is a highflow so it would sound better than a stock turbo!and yes i know they are illegal and i know about the fines!
https://www.sau.com.au/forums/topic/183337-wtb-screamer-pipe-for-r33/
Do you even know what your asking for ?
A screamer pipe should only be run off an external wastegate, which you don't have seeing as your only running a highflow. If you just want to drive around makeing lots of noise then simply remove your entire exhaust system.
yeah,i know all that dude!!!if i am going to do i am going to do it,but i have heard some that sound ok,but i am not going to do if it sounds shit,i know it will sound heaps better and if you have an external,but i am crazy :D
ive seen screamer pipes on internal wategated turbo's - they've just had a blocking plate put inbetween the gate and the turbo outlet like strich9's
ohh and jasons (hyper31's) is pure porn to the ears!!!
yeah,you guys are right,it would be better if i already had a gate on my car,but also how would it sound being that my car is auto,pretty sure it would only vent on full boost,tell me if i am wrong?i have heard hyper31s screamer,sounds insane :ninja:
Mine sounds OK on HKS 2535 - but there's a partition (totally blocked) between the exhaust output and the wastegate output :ninja:
my highflow is probably rated the same as your turbo,so it should sound ok?my turbo is a stage 3 highflow from sliding performance and is rated at 270rwkw,about 360hp at the wheels!
Its not the size or specs of the turbo that makes the noise, its the physical wastegate, and then the diameter of the screamer pipe itself has some influence.
Pleanty of china dumps with screamers for stock turbos on ebay dude, just open your eyes. But everyone has warned you.
I didn't have one put on, that's the way they are from the factory.
Yours has an open hole between the wastegate and exhaust, so it will sound like crap. Highflows still use the stock housing.
looked on ebay already!!nothing on there at the moment,only for silvia and supra!
I did a search then and found LOADS of split dumps, just do a cut and shut yourself :)
Maybe masTers was right on the devine intervention (only for you)
devine intervention,give me a break!!!my search was for screamer pipes!!!only three come up,i know there are heaps of split dumps,under nissan performance parts!
get a split dump mate or even better a justjap racing dump /front which i can then modify for you .
kermit
cheers,sounds good!will buy one in the next few months and will get you to do it,how much am i looking at to do this mate.the justjap ones are very good,i have only got a x-force mild steel dump pipe on my car at the moment.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
