  • Replies 682
<br />The Shirt man just needs to work on the launch\'s more. a year off the track and then back to it with a completly different setup will do this too you.<br />
<br /><br /><br />
It\'s more of the that fact that he needs to simplify what he needs to do to launch, so he doesn\'t have to call NASA every time he wants to take off. I believe he is working on getting the setup done for this now.
NASA? lol he only has one switch on the steering wheel. its not rocket science. Mark set it up to be as simple as possible. he needs to work on the clutch when taking off he was saying.
he was also talking about using the line locker to load up the transmission and drive train to help get off the line at the 2nd staging lights . So that\\\'s 2 buttons (ok one is being moved to work off the clutch pedal) plus having to worry about the tree at the same time while all this is going on. Pretty complicated if you ask me, only gets better with practice.
By the way, you need to change your signature now that you have run a 11.1. Well done on that
Edited by Deano45
im going to run the line lock and anti-lag off the 1 button...simpler set-up
light the top light...press the brake...push the button...inch the car into stage dragging the front wheels in with the driveline loaded up...light the bottom light...floor the accel...slip the clutch...let it go on the 2nd yellow...hang on to it the best i can...avoid the walls and car in the other lane.
Due to the fact we were unable to get the power to the track it ran 10.00 @ 144
the 60' was a very slow 1.8...4/10's slower than my best...4/10's in the 60 is 8/10ths at the end of the track so it was a 9.20 car with that power.
its a really hard car to drive now...Dave (T04GTR) said he was surprised how difficult it actually was to get the car down the track. Racing a car of this calibre is not as easy as some may think, there is a very fine line between bogging the launch, blazing the tyres, keeping it off the walls and a clean quick pass. I tip my hat to guys who have ran sub 9.50's in a GTR on radials as its not childs play.
Being part of the Godzilla Motorsport team now means i have access to one of the best teams in the world at car set-up. Mark Jacobsen knows exactly what the car now needs to perform and we will be making some changes to the car, setting it up to launch in the same manner as his 7 second car. A lot of these set-up changes involve keeping the driveline loaded prior to launch and keeping the turbo on boost as the clutch locks up. Scott Kuhner from Insight Motorsports has also joined the team and his knowledge has also been well recieved.
Ive got 39 passes under my belt now so im getting more and more experience with how this stuff is done. To run sub 10's on my 24th pass was a massive achievement...to run sub 9's on twice as many passes would be incredible.
What's this going to do to driveline wear and tear?
hey Paul how have u got the line locker hooked up, is it holding on the front brakes or deactivating the back brakes? i am trying to sort one for my car i have the solenoid etc but the front brakes have 2 individual lines (one for each side) coming from the master and im trying to work out how others are doing it. I dont want to have to hold the brake pedal on i want it holding the fronts on for me, but wondering if Teeing both front lines into the solenoid and then dividing the lines after solenoid is gonna work without any problems.
its better for the driveline as it eliminates shock loading the driveline...its murder on the clutch though.
Brad i run an ABS master cylinder which has only 1 feed to the front brake hydraulic circuit...you run this line to the locker solinoid and then tee the other side of the soliniod to each of the front brake calipers.
  • 1 month later...
From the godzilla motorsport site:
Vi-Pec Tuned V88 Makes 807hp.
15-03-2009
Paul Diemer's "Twoogle" GT-R running a new T51R turbo setup and Vi-Pec V88 ECU was tuned by Godzilla Motorsport prior to the recent Compak Attack in Sydney and made an impressive 807hp at the wheels. This is one of the first Vi-Pec ECUs to be utilised on a high power drag setup and Mark was impressed with both the features and ease of use, comparing it to the Motec M600 ECU used on his own drag car.
The next step for Godzilla Motorsport: a Vi-Pec V88 on their own methanol breathing 7 second drag car.
807whp nice work paul. Wonder what that would be at the hubs? :P
Edited by Ryan1200
  • 2 months later...
The car is being looked at in regards to anti-lag set-up, clutch air gap (need more travel with the slave), tune is being tweaked for more power etc.
Hope to get it off the line more consistently and be competitive.
Will be track testing prior to event.
Ill keep you posted.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
