  • Replies 187
i'm a new car detailer so i'm picky when it comes to cleaning my cars (those that know me know this)
i'll be around the day with a huge box full of cleaning stuffs if anyone needs anything. i'll be there in a red rb20 r31 wagon and a white over silver r31 sedan (i'll be driving the white one) :dry:
Edited by Silhouette31
i have one answer for you all to make it easier when it comes to cleaning the exterior of your car............permagard + permagard waterless wash
its the shit, im using it if your skeptical about the waterless wash. demo sat nite at stadium drift when i get there :dry: cause i aint cleaning my car till then
after trialling waterless carwashes at my work before, its absolute crap compared to washing a car properly with water.. and waterless takes longer too.
but eh. each to their own. i wont touch the stuff personally.. i prefer not to scratch my paint everytime i wash it :w00t:
and knew no what thats exactly whatn i thought too, but premagard water less wash dosent scratch paint, its amazing stuff it really is,
the other day i used it, now at the time my car was grotty as, had a large amount of bird poop on it, and it felt like all the grit in the world was plastered over it...........
after using the waterless wash it felt like i had just polished it........
i had used permagard pd 3-3 1/2 weeks ago, as i did it the night before gazzanats.
it really is amazing stuff. no bull :w00t:
or just jump on the tram and head to the bay, bunch of friends did that last year.
But yeah, a seat, munchies, dont really need much.
Think PK said already, but PM's will be sent out soon to everyone entered, letting them know the meet up time/place etc
Well I didn't put my form in as Im pretty sure I'll be busy on the sunday :rofl: However Im hoping to make some free time for the friday night cruise.
If PK, Flick or someone could email me the cruise details, I'd like to head to the cruise on friday at least.
Cheers :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
