Hey,
Im currently in the market for a new clutch for my R32 gtst (which will only see 200kw atw in the future)
With so many clutches on the market, with different names and parts, which one would be the best/easiest for daily driving?
So far in mind are;
Exedy H/D Clutch - Genuine
Exedy H/D Clutch with Pressure plate rated @ 1050kg
Exedy Sports Organic Clutch - Genuine
Exedy Sports Organic with NKK Pressure Plate
Exedy 5 puk Button Kit with Pressure plate rated @ 1200kg
I heard the Sports organic is a much easier clutch for driving than the H/D and also holds more power.
Although not sure where the 5puk button kit falls into this comparison
Thanks
Patrick
https://www.sau.com.au/forums/topic/183640-clutch-confusion1/
Have had the Exedy HD with stronger pressure plate fitted in my 32 GTST & it had a nice feel to it. Slightly heavier than stock but not enough to even bother my mum. However, on a fairly stock RB20DET (exhaust, intercooler & boost), I managed to kill it in 12 months & 13,000 km's. I am a very hard driver but I was still expecting more... Have now fitted an Exedy un-cushioned 5-puck brass-button clutch & I love it! Stiff as hell, with little to no play in it, it sure isnt for everyone but is a lot easier to drive than I would have imagined. Just takes a little getting used to...
Is there a lot of difference in pedel feel between 800kg and 1000kg pressure plate?
It's either Exedy HD w/ 1050kg PBR plate
OR
Exedy HD w/ 800kg Exedy plate
Only $100 price difference between them, 800kg easier to drive in traffic or no difference between the two pressure plate loads?
Thanks again
Yo dude, thought I might add that I put a new clutch in my 4 door r32 drifter not long ago. The clutch was from CBA( clutch and brakes australia ) and cost me $500. It was a ceramic coated 5 puck with a 1100 or more cant remember pressure plate. This was the heaviest duty clutch I could get without going to full race spec (which dont last), and it was easily drivable as my daily gardeners car also. Whilst on the r32 clutch topic I thought I might ask if your going to keep or bypass the loop bit in the clutch lines that makes the pedal feel softer ? If bypassing do you know if you just block the outlet and inlet for this loop with screws or what?
Edited by ryano
mm sounds like the HD is the way to go.
Anyone had any experience with Sports Organic clutches?
Cheers
If your a confident manual driver man go with a EXEDY 5 PUK BRASS BUTTON. Can take up to 300rwkw and will save you time later when you drive it hard, or push the car for some more rwkw.
That way you wont have to worry about it breaking, but might strain and blow the box first lol
Doesn't take that much getting used to, if you drive manual frequently you will pick it up in a few days.
Abu
Edited by abu
hey mate i just recently put in an exedy heavy duty cushioned button in my r33 i got 210kw at the wheels and its real good, grips heaps well and the pedal feel is a little heavier but not to much heaps better than the 5puk for every day driving still can slip a little i would reccommend it im very happy wit it.
Anyone recommending a button clutch has either driven on them for the last 4-5 years or it's their first one and they haven't had it long.
People who think button clutches are easy to drive are wrong, You can make them easy to drive but by driving it like a regular organic clutch, it will wear out in close to 12 months. To drive a button clutch is to drive it harsh, no riding...just in or out/on or off. Damages driveline and other components.
Only recommended if you are willing to replace it in 12-14 months and keep learning to drive it properly. Sometimes there is no option but to run a button clutch if power levels exceed a certain amount.
The Exedy heavy duty clutch will hold up to 240rwkw. If you don't to ghey stuff like flat shiftingand 6k launches, then you will not break it.
If you are local to Brisbane we are fitting these clutches for $715 including flywheel machine and spigot.
If you want something a little heavier then you can request the NSK-7056 kit with the NC10T pressure plate. This is the 1100kg pressure plate, and is the true antiburst/antislip cover that exedy make for Nismo. These are a fair bit more expensive but will hold more torque and last longer.
Just remember, you don't need to go overboard but you do need to consider what the car will be used for in the future because if you decide to add more power, then a different clutch may be required. Careful consideration is required to make sure you don't waste your money.
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
