Yep, GTR injectors are 440cc.
I know the standard injectors are 440 cc but
will the 550cc be able to do it without needing a fuel pressure reg and with a little head room on top
what i'm trying to say is what do you think the duty cycle will be on with say 350AWKW on the 550cc injectors??
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3326535
I have a nismo 275lph pump, and nismo 555cc injectors. They are running 300rwkw, and are at about 80% duty.
I reckon they'd see 320rwkw easily, and more with a FPR up their ass.
But i'd just go for the 770cc Nismos, as they are about $5 more. Also, people on the datalogit user group say they have absolutely no idling troubles with large injectors (up to 1000cc).
770cc Nismos are the best bang for buck IMO. Wish I got them.
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327144
I was going to post up this same topic. Iam getting my car tuned in a few days time and will be aiming for 300-330rwkw whilst using denso 550cc injectors. Ill prob use a FPR though just so I can get a little more out of them. As far as 350awkw you will definetly be pushing it especially without a FPR. If you havnt purchased the injectors yet definetly go the 700cc....
Ryan
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327287
just for referance. i used bosch 650's. with poncams. at .85 bar they were at 75% duty. (i was aiming for 400kw.) with standard cams on 1.5bar they were at 80% putting out 315awkw.
and these are 100cc bigger! id be safe to say 550's on 100% would strugle to safly make over 310.
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327517
What are they going for dollar-wise?
A set of sard 700s were $480 from nengun a little while ago.
Nismos seem to be double that at some places.
For GTR you cant go past the sards if the spray pattern doesnt put you off
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327908
Thanks for all the post's guy's i think i'll be going for 700cc injectors
is that what the sard's usually go for?? and are they direct bolt in replacment??
Cheers
anthony
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327926
yeah the sards go straight in. They sit inside the head slightly further than the oem injectors and other after market ones because they are a generic injector. The only downside (this depends on what side of the fence you sit on) is the spray pattern is a little more *squished*, if that makes sense. But by judging by the amount of ppl that use them and the great results they have, then it really shouldnt be a problem. Check out the rb26 dyno thread for proof.
The $480 was when the yen to dollar ratio was the best a couple of months back....i timed it right :P
theyd be low 500s atm i *think* (on nengun)
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327947
Nismos have a much better spray pattern as they are a 4 hole injector.
Also the sards are cheap because you need to get Collars for them, and are usually an extra $200 - $300
They are not a direct replacement.
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3327975
The maths to work out how much power your injectors will handle is simple (there are more accurate ways but this is damn close)
(CC of the injectors used) divided by 5 times 6 (the number of injectors used). That calculates how much power at the crank your injectors can handle at 100% duty.
EG.
444 / 5 x 6 = 532hp @ 100% duty at the crank
550 / 5 x 6 = 660hp @ 100% duty at the crank
740 / 5 x 6 = 888hp @ 100% duty at the crank
So running at 90% duty you could make around 480hp at the crank minus drive line losses using the 444's
So running at 90% duty you could make around 600hp at the crank minus drive line losses using the 550's
So running at 90% duty you could make around 800hp at the crank minus drive line losses using the 740's
I have seen 444cc injectors holding 350+kw @ the wheels 12:1 AFR's.
You don't need to run massive injectors to get the power figures you want.
https://www.sau.com.au/forums/topic/183647-gtr-injectors/#findComment-3328818
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
