so did anybody notice that the 2 middle pics are the real Rolls Royce phantom, and the 2 outer pics are a chinese made copy by Geeley Automotive?
Yeah Kujotk we've seen these cars on the radar at work for some time now, I personally can't stand the copying of designs, it's ridiculous and shameful, but unfortunately it's typical of a developing (as opposed to developed) market and some might say, of the culture.
That particular Geely has a "throne" rear seat where the VIP sits in the middle of the car...
Awesome car; I think it's the only road-registered Pagani in Australia? It's the same colour as the one shown at the Sydney motor show a few years back and possibly also a few other events; had the NSW black on white number plate "PAGANI"?
Not sure although a friend of mine who I showed the pics to mentioned the same thing about this car being from the motor show etc..
spotted a yellow Pagani Zonda driving around st leonads this arvo....and it was registered WTF!!!!!
In a dealearship, Crown st Surry Hills.. had to stop to take some photos!!
I already spotted it driving a few months ago, a day I'll never forget... difference is you got pics of it
You cannot register an F40 on any Australian Roads. Take a quick read below. Quote from 360c from Aussie Exotics, who owns a F50.
It is illegal to drive them on trade plates too. Just because you see them on trade plates doesn't mean it's legal.
For more information go here.
F40 can be registered, here is proof, but you need buckets of cash to be able to afford to buy one and bring it over.
The F50 can't get registered
http://aussieexotics.com/forum/ferrari/fer...10-t6969.0.html
F*ck I love 80s Italian supercars. Awesome photos of the F40. There was one at the Classic Throttle Shop some time ago, I had a good look over.
Wonder what F40's are selling for these days?!?!
Found the one; looks like it was listed at around $700,000 (bargain :cheers: ) not sure what it sold for though.
Probably my favourite Ferrari of all time and one of my fave cars full stop.
http://aussieexotics.com/forum/ferrari-for...le-t4817.0.html
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
