saw a black Ferrari 458 italia in the city todayon Sussex street in Sydney CBD. Wish I could have gotten a photo but was driving. Must be one of the first in Australia??
Yup, it was the first in AUstralia, it is the demo that Italia Motori use for product launch, test drives, something for buyers to look at. Was it around lunch time? They usually drive it up to the CBD for appointments for test drives by ceo's and what not...
Oh, I spotted a wine-red late-model Lotus Esprit (possibly a V8) somewhere between Castle Hill and Baulkham Hills last Friday - can't remember exactly where, unfortunately.
Such a cool car
The TT ones don't have bucket loads of power but it's SO nice inside
Plus the noise they make at idle is to die for
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
