They are dark gray
Offset is same as GTR but I've fitted spacers
Spacers are a car's worst enemy, no matter what anyone tells you. EG: It bolts on, to your hub.. bla bla bla..
There's a reason why rim manufacturers make different offsets, to suit different needs, and not just chuck spacers on them to sell.
There was this lexus @ the autosolon.. some of you might remember it... his front wheel flew off while driving cause his so called forged spacer bolted onto hub gave way. Luckily he was only driving at low speeds, if not.. GG.
I rekkon, get rid of the spacers. my 0.5 cents worth.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
