  • Replies 46
Just spoke to the dealer, they took a deposit in good faith this morning. They estimated $120,000 and the final price has not yet been released, neither have the final specs. The only thing that is known for sure is that we will only get one model and they are hoping to start landing cars early 2008. No official announcements until the official release at the Tokyo motor show.
https://www.sau.com.au/forums/topic/183933-want-a-2008-gtr/#findComment-3331357
I confer...
https://www.sau.com.au/forums/topic/183933-want-a-2008-gtr/#findComment-3331395
I have a feeling Australia's going to recieve the lowest model of the GTR's.
Exactly what I was thinking when I read the first post.
Come on Nissan Australia, if you're going to bring in one model of the GTR, make it the best.
Also since they're bringing it in officially, if we get the low end model, we can never import the high end model from Japan.
https://www.sau.com.au/forums/topic/183933-want-a-2008-gtr/#findComment-3331546
Pretty much what I was thinking.
https://www.sau.com.au/forums/topic/183933-want-a-2008-gtr/#findComment-3331559
Japan has always had a history of doing that.
Im sure there are a huge number of factors as to why the lower spec car will be sold but guys quit complaining.
Its GOING there! better that than nothing at all right? Youd have every right to complain about it if the GTR was never going there..
besides the last locally sold gtr was the 32 and that was years ago.
count your lucky stars boys and girls! :sorcerer:
https://www.sau.com.au/forums/topic/183933-want-a-2008-gtr/#findComment-3331624
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
