What an angry angry engine, Finally got it to run after a hell of a lot of dicking around. Man i seriously felt like pushing it in to the back yard and parking it permanently. Thank god some young fellas have more patience than me.
Mick and shane plugged away while i went and sulked and before you know it its idling and it sounds like armagedon.
Wonder how many mufflers you can fit to a gtst.
Shane and i drove it round the block and all systems appear to be working, brakes are an issue. hard hard pedal and very average stopping power.
Hopefully it goes on the dyno tomorrow , Mick the magician can cast his spell on it and make it quiet as a church mouse with a gazillionty horsepower. :P
  • Replies 187
Posted Images
ahhhhh i just had a fat attack, i dont want to sell mine now.....i want to put the 25 in it.
That sounds farken stoopidly horny old man, shotgun a straight line run in it. i dont want to go round corners with you with that much power.
Just make sure you dont break it.
So what was the problem anyway?
Can it be told or?
Can it be told or?
Sure mate, No secrets here. It wasnt one problem as such but several very annoying stupid niggles.
Wrong injectors first, then a crook afm, then a dodgy signal wire from the afm to the puda, then a cas niggle. It was really starting to piss me off. On top of that the puda didnt recognise any of the engine settings till magic Mick tapped out several different sets of new numbers on the lappy and away it went.
It hasnt been tuned yet, but hopefully that will happen today. The numbers are all safe for me to at least mosey it around to the workshop and thats excactly what i will do shortly.
Sick!!
can i push the accelerator at some stage??? while stationary of course.
Its kewl dude, i've seen you drive remember. :thumbsup:
yeah true, did you still want to take a ride in mine to check the suspension?
just letting you know after talking with a few people, if mine doesnt come up to scratch i will prob be looking to put SK's gear in it. but if mines ok then it'll stay, but my ride height is gaying up my handling atm...which is kinda surprising how it will handle when it is set right.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
