Hey
You can use an original WALBRO pump, they are about $160 delivered from SLIDE in the for sale trader section.
BOSCH 040 I believe is the one your chasing, that is also a good option.
Personally would go for an original WALBRO as they are very reliable pumps. Few people pushing 300rwkw with them, as well as being very easy to install!
Its been covered heaps on the forums. Check the DIY/tutorial section and you will find and installation guide more than likely, also search the forced induction section for like "what fuel pump" and you should get a lot of results.
Good luck.
Abu
Edited by abu
You can use either, the 040 has a filter built in and has to be mounted low, the 044 uses the standard sock filter and hose. If your r33 is stock you don't need either, if it's making 220rwkW - 280rwkW use the 040, if it's making 280rwkW - 400rwkW use 044.
Dont skimp on you fuel pump choice,go Nismo or Tomei,they are direct fit,and will easily cater to your power goal.
atm i'm making 180atw
but aimming for around 220-240
so i guess the walbro would be ok for this target?
cheers guys
yes it will be ok for that target but not much more
if your dead set you dont want no more than get the walbro/040 but MAKE SURE you dont want to go more because you will end up buying twice like alot of people
if i were to do it again, id spend the extra $250 and get a nismo/tomei from the start (ill have to do this when i change the turbo)
TOMEI or a NISMO?
Man if you got the cash to spend $500 on a fuel pump then go ahead.. but a WALBRO pump for $160 delivered will serve you the EXACT same purpose.
There is a guy with an R33 which is running 300rwkw on a WALBRO pump.
http://www.skylinesaustralia.com/forums/in...=167572&hl=
Edited by abu
theres been alot of people that have had problems with walbros running lean as they get higher up
sure they should handle up to about 300kw but usually they dont
i have one and its fine but im only running 200kw..
anyhow its just what i have read from others exprience so dont take my word for it
there is a fuel pump control module (FPCM) which regulates between a low and high volume mode, other then that it just pumps either of the 2 modes, that being said in your engine bay is a fuel pressure regulator (FPR) which regulates the pressure of the flow into the fuel rail meaning that the pump just pumps at its one speed all the time and the FPR regulate it for you.
that why these guys are saying it doesn't matter which pump you go far, if the WALBRO is leaning out up top its because it pumping at maximum pressure / volume and simply cannot supply more fuel.
the FPR cannot up the pressure provided by the fuel pump merely reduce and regulate it
Would there be any problem with running a Tomei pump on a stock (with turbo back exhaust) R33 GTST. Would it run unnecessarily rich or does it only pump what is required?
You wont have any problem at all, it'll run fine (fuel reg will regulate pressure).
After much research and pondering what pump I should install (040, 044, Walbro 255, Tomei kit etc) I came to the conclusion that the Tomei kit (has everything you need including new seal, clamps, harness, wiring etc) is well worth the $360 advertised in the classifieds of this forum. It was a easy direct install with no modifications.
  • 8 months later...
I've just bought a new Walbro fuel pump from Slide, should be here on Monday.
I opted for the Walbro because I'm only aiming for around 200rwkw.
hey just wondering that walbro fuel pump that you got is that from the trading post
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
