Guest Tempest
Now there is something i am somewhat unclear of...
I have asked twice already if you import a car from japan do all mods have to be removed and destroyed... Both times i have got the answer "correct"
Now.. could someone explain why it is that anyone would purchase a car "highly modified" if all the mods are to be taken off before they actually get it?
This may seem very noob of me but i intend to import soonish.. and i am getting some idea's of how it all works.
I downloaded the FAQ's from www.prestigemotorsport.com but it didn't answer the question fully...
https://www.sau.com.au/forums/topic/18421-car-details-before-purchase/
  • Replies 43
It is dependant on how the car enters the country, so there should be nothing to stop you taking off the parts overseas and shipping them with the car .. as long as the car itself is 100% stock and any aftermarket parts are not fitted prior to registration.
it all seems to simple to remove the mods and get them shipped over seperately ... its going to cost $'s to:
a) remove the mods
B) source stock bits
c) install stock bits
d) send over original mods seperately
e) re-install mods when landed
i wonder by the end of it how much you've really saved...?
  • 2 months later...
Question:
When is a RAW NOT a RAW?
Answer:
When they leave on or re-fit after market(non-conforming parts) with-out evidence!!!
This is going to be a huge problem for "some" of the RAW workshops here in Aust particularly the ones importing Skylines,as to import and sell a stock33 will be about as saleable as a" pair of trousers filles with African killer bees" . and some Raws have allready gone out and publically said"If they think I am going to remove a S/Steel Trust exhaust of a vehicle and destroy it ,they must think I am a F%CK$# Idiot" un-quote!!!!
I wonder how long someone will be a RAW for with that kind of attitude?
What would happen to somebody who has paid a deposit to a RAW to import a modified Skyline, and the vehicle gets inspected and the RAW gets an audit and nailed? where would that leave the client and his vehicle???
Can someone PLz answer this question
A raw without a licence... workshop... and probably in Jail.... or fined heavily.
The customer..... without a car... and probably out of pocket a lot due to the car (probably) being destroyed or re exported.....
(Just guessing here)......
hehe..
anyway, i wouldn't be trying to get an importer to push the rules as they'll be regular inspections. The only people that are going to suffer from this are those trying to do the dodgy, or you when you're car gets taken back or destroyed. That is one of the whole reasons the new scheme was brought in the first place, to stop some of that from happening.
Originally posted by P1E
I am currently importing a vehicle through Geoff and he has assured me that this is untrue. :confused:
Yes, that is true - ALL aftermarket parts will have to be destroyed or re-exported with evidence provided to keep the RAWS out of hot water when they get checked out by the DOTARS.
At this stage it appears that this may even include stupid things like gear shift knobs and additional gauges .. nobody really knows how strict they will be with enforcing these laws so it will be a case of "better safe than sorry"
I would not personally suggest importing any car with modified parts unless you are prepared to lose them and wear the cost of buying stock parts to replace them .. trying to "sneak" anything through at this stage would be just plain stupid for you and beyond belief for the RAWS workshop.
Hi Pie,
If you are talking about a 15Y/O vehicle, a/m gear can be left installed as the only dramas you may encounter will be the local Licencing authorities. and it may just be a case of removing some of the parts to licence the vehicle.
Although if you have been "promised" a vehicle imported by a RAW(SEVS) vehicle with the non-conforming parts retained or re-fitted then be very very carefull. In fact if anybody from"DOTARS"is monitoring this thread then I would say you are allready shot! and possibly the company you have mentioned!!!!!
I would guess that if a RAW was caught out with your vehicle in his premisis that was signed -off and found NOT to be conforming to his evidence ie:17" Rims fitted or S/steel exhaust ect then you would be without your vehicle, and DOTARS would not care who owns it ,as it would come down to a legal claim between you and the RAW, not DOTARS.....
I'm looking to import a relatively stock Series II R33, although a couple I have looked at have had a few small extras (GT-R seats, rims, gauges, etc.).
I was originally under the impression that all aftermarket parts had to be destroyed, but Geoff explained that such rumours are completely unfounded.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
