So I had an upgrade done with new turbo's etc by a Sydney builder/tuner.
I'm running into several problems running around Canberra.
1. The car runs rich, so much that it spits out carbon deposits and lots of them.
2. The power FC says it uses up to 100% injector, the sales rep at the tuning place recently told me not to worry about the figures they were not to be trusted (this from the same sales rep that told me that more PSI doesn't kill engines).
3. The car will occasionally and only under light throttle, give a kick like the fuel has been suddenly cut off then reapplied.
4. The fuel usage is very high, 300-330km per 50litres no matter what level of boost I have (11-18 PSI), before the upgrade I was getting 400+km on 15psi.
R33GTR 265kw at 18psi
2860-5 turbo's
Power FC
Boost controller
Cam Gears
Panel filter
Spitfire coils
Still running the same AFM, injectors, fuel pump
I realise that there are differences in climate from Canberra to Sydney, but the tuners claim to be world class. I feel I've been fobbed off by the sales rep many times and I'd like some ideas to ask the tuner etc when I next go down to Sydney. Why the hell should the computer running my car not know the correct injector utilisation. Opinions and ideas please.
https://www.sau.com.au/forums/topic/184304-power-fc-injectors-at-100/
2860-5 turbo's
Power FC
Boost controller
Cam Gears
Panel filter
Spitfire coils
I am having exactly the same problem, and getting the same advice from a very reputable workshop. I will be upgrading to bigger injectors in a few weeks, but still not convinced that will fix my fuel issue (20L/100kms, but I do not get to drive far at all with the car off cold start)
it sounds like it's running too rich but the injectors can't handle it. i wouldn't advise going back there ;)
After paying $9K for the parts and tune, I'll be going back as many times as it takes them to fix it. I'm not impressed with their attitude and service at all.
Damn, you'd think you could get some service after spending that sort of money at a place.
There clearly not worth the trouble.
Edited by abu
it depends when you are hitting %100 duty
if its at 7100rpm then its fine
if its at 5400rpm then its bad
do a test and see when its hits %100
also get another tuner to check over the tune and do a dyno plot with AFR to make sure its not leaning out (if its hitting 100% at 5400rpm for example then it wil be leaning out)
This is where things get interesting, a lot of people, who I would expect to know what they are talking about and a few that I actually trust as well say that 100% injector duty cycle while is not that nice will not do any damage if there are no knock issues. On the other hand there are many people that think it is the worst thing in the world to go above 85% duty cycle.
I have no knock issues (30 max on WOT), does not hit 100% unless I really push it. I am still upgrading injectors, FPR, coils as soon as I get the cash together.
21L/100kms is not nice on the pocket though, could this be JUST due to me driving mainly < 4km trips (i live very close to work/uni/shops) and the water temp is only just warm by the time I stop.
This driving style will change to min 20km trips on open roads next year, I am really hoping that things improve out of sight then.
to go frther you need to find out when it hits %100
until then you cant do much
Exact RPM I am not sure, but it is not until very high into the rev range, at a guess 6800+
I want to put in 555cc Nismos in, but do not want to make my short distance fuel economy even worse. Cruise seems to be fine, about 10L/100kms in more open driving.
well the best way to progress is to dyno plot it with;
afr
fuel pressure
power
so you can see how the car performs and check afr's
you will then know if the %100 is causing an issue or not
youll also see power delivery. then once thats done, do a light load dyno plot so youll see what the light cruise / medium afr's are like
and lastly before you do anything else check 02 feedback is on and you have working 02 sensors. some tuners disabled them during dyno tuning and could possibly forget
Hitting 100% around 6500 at 18 PSI, but the engine revs to 8000. Hard to tell while driving.
Problem is driving to Sydney cleans up the shit coming out the back. Sales rep keeps coming up with the same line, "well GTR's are dirty motors, they have to run rich". Or "you will being getting worse fuel economy when you drive it harder". Doh..
How do I "check 02 feedback is on and you have working 02 sensors"?
Edited by a20089
I saw this car the other night. One blip of the go pedal and the car literally shat a puddle of fuel out onto the tarmac lol. Ouch.
John, like I said the other day, I've had my car at like... 5 places (and multiple times each) to try and solve suspension woes. I know you paid a lot, but like others have said, when all's said and done, if they are too retarded to fix it, and spining you BS lines, I wouldnt be going back! I went back to Jax Quickfit like 6 times (because they had a satisfaction guarantee) before realising I was wasting my time because they are clueless. Cut your losses and try John @ Trojan ;) He's had one of his personal cars in HPI, he's a heck of a lot closer than Sydney...
Hell, he might even look at it for free/cheap and give u his idea of what's wrong, if you're REALLY keen for the Sydney tuner to fix it. I've used this method when I deserve something to be fixed by the place I bought it, but they were simply too unskilled to see the problem.
I wouldn't recommend running your injectors
at a 100% injector duty cycle as you risk detonation.
The reason being that as your engine consumes some cold (dense air)
it will require an equal amount of fuel for combustion, so if your
reach 100% duty at say 5000rpm you lean your AFR out and starve
the engine from fuel! As the injectors can no longer meet the fuel demand!
The std. injectors are approx 375cc so in general will
only support a maximum of 375hp at the engine.
To add to this, running a far too rich AFR will also increase
the level of knocking in the engine due to 'heat spots,'
caused by the build up of carbon deposits on the piston head
from over-fueling!
Good luck!
Go to a tuner
Not the local butcher! :laughing-smiley-014:
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
