Ok from the start....
Ive got a Greddy Informeter which tells me the water temp, 02 sensor voltage etc in the car and over the last month or so ive noticed the water temp goin up, i think its even hit 100 degrees!
Anyway, i babied it to the mechanic and basically flushed out the coolant and replaced the thermostat.
Got it back and still running a bit hot. Mind you the standard gauge was sitting on normal.
Decided to take it back and do a 100K service which included the water pump, belts, spark lugs etc...Still running hot when i got it back, i think i even saw it go past 100 and the standard gauge went up about 10mm! Obviously the Oil temp went up also, it hits about 100-110.
There are no coolant leaks, no discloured or bubbley coolant so i dont think its a headgasket, ive have replaced the Coolant Temp Sensor on top of the block, bled the system again and again.
I notice when i put the foot down the temp will rise, but steady driving it will sit on about 96 - 100.
I put the heater on flat out to cool the engie down and that seems to work.
PLEASE HELP DIAGNOSE! searching hasnt helped much.
Could it be that the fan belt is a bit loose and not working to its full potential cos i have a hunch its loose??
I friggin pamper this car and never miss a service.
Of course check the fan belt. (Although you would also have battery troubles.)
Are you still running the factory VC fan? And the shroud? Cams are not out of alignment? Timing is correct?
are you sure you have a reliable baseline to compare to?
you state that your standard temp guage looks ok .. so I guess what I am trying to say is are you sure all the other 34's dont operate at this range?
maybe just because you can now see a numerical readout of the temperature vs a guage readout your just a tad paranoid? I was under the impression ( and someome PLEASE correct me if I am wrong ) that standard radiator systems can get close to and above 100 oC ( boiling ) and not boil over because they are a sealed system
I am by no means an overheating guru but thats just my thoughts on the matter.
Workshop guide states that it should run between 82 - 95 degrees.
Thats what it used run before the temps started to rise.
I thought the standard gauges only start to rise when the system is getting very hot.
I'm with ssshonky...if the standard gauges read normal then you should be fine? IF you didn't have the Greedy infometer you wouldn't have a clue and think tht everything is ok? Unless you had the infometer prior and it was reading lower? If you get what I mean?
I know what you mean, but when the Greddy digital gauge shows past 100 degrees, the standard gauge starts moving up, and thats with normal driving.
Is there another sensor that could be playing up by any chance?
Ah ok, if the standard water temp gauge starts moving up then u may have an issue. Mines never gone past the normal spot just below middle.
Did you actually flush the radiator? or just drop the fluid? theres a difference.
In my old car I did the latter which actually caused a blockage which caused to overheat constantly until sorted.
I'd recommend taking getting it looked at by a radiator service place (like NATRAD) and get it flushed properly.
But try tightening belts first...
Hi mate,
Firstly i used to have the same issue in my old gtr,
Turned out to be the radiator's top tank was clog up, i removed it, took it to a radiator shop, had the top tank removed, clean + new seal, $85 and the heating issue was gone.
Also after you've flush the radiator, while toping up the coolant again, did you jack the car up a bit, had the heater at full blast and bleed it through that little screw on the side of the block?
yeh the use of the bleed screw is good information indeed! perhaps a pocket of air is causing problems
so the Greddy guage has its own sensor.. so if the 2 ( the Greddy and the factory guage ) both increase at the same time you can basically remove the possibility of one of the sensors being dodgy.
now.. I am not sure on the skyline motors but on the sr20det's I know there are 2 temp senders
one that sends info to the guage and another that feeds the ECU the engine temp .
so maybe clean and re-seat your temp sender?
Is there a menu in the Greddy thingie somewhere for calibrating it to your sensors? Next tiem you start teh car from cold see what it is reading. If its reading 20deg higher then ambient or somethintg weird then can it and just go on the std gauge
I have the same problem at present, I have taken the theromstat out which didn't open at all, fixed that problem
and temps still read 95 degrees.
I have now got a GTR N1 water pump comming, and am taking the radiator out to get it flushed tomorrow.
hopefully this solves the issue.
My bros r33 gtst has an apexi water temp gauge and it sits on 78 degress all day long, no matter if you boot it or not.
100degrees is too hot for a rb and it is not normal. In saying that its not in the temp range to do damage, but its definately not at the proper operating range. You said that if you put your foot down that it starts to climb. This shows that there is a restriction in your cooling system, and as you start giving your car a flogging, it creates more heat and if the cooling system can't disperse this heat obviously your temp will rise.
So, luckily cooling systems are relatively simple and you have covered the main areas already:
- new water pump
- new themostat (is this genuine? i will never still aftermarket thermostats in any of my cars, i have had too many straight out the box not working right and actually causing overheating)
-new coolant
-radiator cap (cooling systems rely on pressure to work correctly, if you have a dodgy radiator cap that releases pressure too low, this can also cause overheating)
-headgasket (generally this is a last resort, but if your oil is milky or you coolant smells like exhaust this could be the problem, but unlikely)
-hoses (its not leaking so i assume they are ok)
-radiator
My guess would to take the radiator out and get it cleaned like it has been said above. It is the most likely cause for overheating, especially if the coolant hasnt been changed in a long time.
Edited by R34GTFOUR
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
