Hi Guys
I am about to purchase a new fiberglass Trust Style front bar from J Racing Australia (in Fishwick ACT) and wondered if any of you had had dealings with this company?
I was hoping someone could tell me if sending them $500 electronically was a wise move (given that there is never a 100% garantee with anything)
Thanks
Guy
https://www.sau.com.au/forums/topic/184730-j-racing/
There are a few topics in ACT section on NS.com. J-racing gets a mixed response, some say there ok, others say their dodgy and overpriced..
http://www.nissansilvia.com/forums/index.p...howtopic=237660
http://www.nissansilvia.com/forums/index.p...howtopic=229695
Edited by Just_Lookin
https://www.sau.com.au/forums/topic/184730-j-racing/#findComment-3343693
Hi Guys
Thanks
Guy
$500 for a trust style or a genuine trust bar? there's a big difference and make sure you clarify that before buying it. for $500 i'd hope to hell it's a genuine, not a 'trust style' front bar.
J racing are known for their widebody work as somebody else stated, but they're also known for their pricing and have a rep of being the place that ignorant boy-racer noobs go.
https://www.sau.com.au/forums/topic/184730-j-racing/#findComment-3343888
A genuine trust bar for $500 LOL
The genuine bottom lip is $800 alone
The bar itself is $450 for a glass copy (i need to add on freight costs as well), and if the quality is OK, this seems to be a good price (many fiberglass bars from other manufacturers are more expensive and the quality can be questionable)
They are also one of the few shops that make this particular bar in Australia (and they have it in stock)
Edited by 4door_Sleeper
https://www.sau.com.au/forums/topic/184730-j-racing/#findComment-3343936
$800 for a lower lip? regardless of what brand it is, that's ludicrous. i know genuine GTR parts are excessively pricey, but damn
glad i don't drive a skyline and have a penchant for gucci name brand bodykits lol
https://www.sau.com.au/forums/topic/184730-j-racing/#findComment-3344048
Hi Guys
Thanks
Guy
I think your money is safe and you may have better luck than I did. Will he let you hold some cash back for final inspection? If so, I would do that just to make sure it doesn't turn up damaged like mine, oops too late... I'd paid for it. Then had to pay someone to repair. He also promised overnight, 10 days later nothing and he wouldn't even return my calls. I wasn't happy.
https://www.sau.com.au/forums/topic/184730-j-racing/#findComment-3344555
