I've always like cars that have the majority of mods from one manufacturer
eg
HKS pod
HKS FMIC
HKS Turbo
HKS EBC
HKS Suspension
Although sticking with only one brand may not be optimal for car performance...
So, name me the brand of the majority of your mods and also how many mods from that brand.
https://www.sau.com.au/forums/topic/184746-sticking-with-one-brand-for-mods/
Tomei forged piston kit
Tomei forged H-beam conrods
Tomei oil sump baffle plate
Tomei head gasket combination kit
Tomei Pon camshafts Type B (Duration: IN 260, EX 260, Lift: IN, EX 9.15mm)
Tomei Oil filler cap
Tomei ornament plate
Thats the most of the same brand ive got even though the oil filler cap and ornament plate are irrelevant (wank!) :P
nismo front and rear swaybars
nismo front upper arms
nismo rear lower link
nismo rear upper link
nismo clear side indicator
nismo frontbar
nismo sideskirts
nismo injectors
nismo 4 point harness
nismo engine mounts
nismo gearbox mount
nismo afm plug
nismo dash
nismo rims
i like nismo!
The list is endless but heres the greatest hits
Tomei 2.8 Stoker Crank
Tomei Forged Rods
Tomei Forged Pistons
Tomei Rod Bolts
Tomei Oil Pump
Tomei Cam Studs
Trust Main Bolts
Trust Type R Blow Off
JUN Head Studs
JUN Cams
JUN Valve Strings
JUN Retainers
HKS Exhaust Manifold
HKS Waste Gate
HKS TO4Z Turbo
HKS Cam Gears
HKS Timing Belt
HKS Fuel Rail
HKS 6 Speed Dogbox
HKS Under Chassis Bracing
OSG Triple Plate Clutch
Hypertune Plenum
Hypertune Throttle Body
Ross Balancer
Apexi Power FC Djetro
Main Reasons for selecting these was Tomei kit i got second hand brand new at good price. JUN Head components were best value and HKS turbo kit suited my needs the best. My opinion is the major Japanese brands are of similar quality. I based my selections mainly on bang for buck.
Engine is being assembled at the moment, cant wait to get it on the road.
Edited by Public Enemy
I don't mind those cars either, mine won't end up like that at all, although be using sard for fuel delivery but that's about it lol
Hybrid intercooler
Blitz BOV
Garrett turbo
Sard fuel pump
Sard fuel pressure reg (sard injectors planned)
Wolf ECU
Xtreme clutch
K & N catch can
K & N pod filter
etc etc
Internals are a mix of CP pistons, GTR rods, arp bearings blah blah....Kit i've got that will be waiting for paint until I got the money up are Bomex front bar & skirts & gtr pods, dare to be different n shit :)
nismo frontbar
nismo sideskirts
nismo injectors
nismo engine mounts
nismo gearbox mount
nismo afm plug
nismo dash
nismo rims
i like nismo!
Any pics michael, would love to see it, im a big nismo fan too :kiss:
I Tried to Keep everything A'PEXi at first, but you just can't do it, sometimes you need things that aren't made by the same company. Instead i've kept almost everything all Japanese.
A'PEXi Power FC
A'PEXi Power FC Hand controller
A'PEXi GT Spec Stainless Steel Turbo Front Pipe
A'PEXi AX53B70 P25 Turbo Kit
A'PEXi PowerFC boost controller kit
A'PEXi Super Suction Kit
A'PEXi Pod Filter
A'PEXi Hard Tune 'Down Springs'
A'PEXi Strut Brace
Greddy Turbo Timer
Greddy Inlet Plenum
Nismo Fuel Pressure Regulator
Nismo LM-GT2 18" Wheels
Nismo Fuel Pump
Nismo Front Bar
Nismo Gear Shift Knob
Nismo Smoked Side Winkers
Nismo Carbon Fibre Side Pillars
Nismo 320km/h Dash Cluster
D1 Front Mount Polished Intercooler
Splitfire Coilpacks
Tomei Z32 Wiring Harness
OS Giken STR2CD Twin Plate Clutch
Fujitsubo Catback Exhaust
Sard Magnetic Sump Plug
All in the process of going on my R33 with an RB30DET :kiss:
Nismo gear knob
Nismo clear indicators
Nismo through over seat covers
Nismo FPR
Whiteline sub-frame alignment kit
Whiteline springs
Whiteline rear adjustable camber bushes
Whiteline front adjustable camber bushes
Whiteline Adjustable castor bushes
Whiteline Adjustable sway bars
APEXi PFC & hand controller
APEXi SAVC-R
APEXi Pod & panel filter
all the rest are random brands.
Apexi Power FC & Commander w/ datalogit
Apexi RSM w/ shift light & G-sensor
B&M Pro-ratchet shifter
B&M launch control
B&M engine oil cooler
GReddy Profec B-Spec II & remote switch
GReddy cam gear
HKS FMIC
HKS SSQV Bov & cross over pipe
HKS Super-Dragger cat back exhaust
HKS injectors
Whiteline castor kit
Whiteline camber kit - F & R
Whiteline adjustable sway bars - F & R
Whiteline pineapples
too hard to buy all my gear from one manufacturer. I just buy the best in whatever part I need. pretty much all japanese parts, and all bought brand new:
Enkei NT03 wheels
BBS LM wheels
Weds Sports TC-05 wheels (yes I have 3 sets for the one GTR)
cusco 8 point roll cage
cusco brake master stopper
cusco number plate mount
cusco rear upper arms
cusco castor rods
cusco 3 litre oil catch tank
cusco front strut brace
cusco under body tension rod brace
cusco rear strut brace
nismo braided brake lines
nismo engine mounts
nismo gear knob
nismo rear LSD
nismo air flow meters
nismo/ohlins G-attack R-tune suspension
trust oil cooler and remote filter kit
trust profec B II
trust hard pipe kit
trust timing belt
trust clear cam cover
trust adjustable cam gears
OS Giken twin plate
OS Giken gearset
Sard 700cc injectors
Sard fuel rail
Sard fuel pressure regulator
Defi BF oil pres
Defi BF fuel pres
Defi BF oil temp
Defi BF boost
Defi warning lamp (for oil pres)
Defi control unit V II
nardi personal wheel
HKS GT-SS turbos
HKS twin 70mm stainless front pipes
Tomei expreme exhaust manifolds
Tomei expreme dump pipes
Tomei sump baffles
Tomei HICAS lock kit
Mines cam cover baffles
ARC front splitter/winglets
Apexi Power FC
Apexi Power intake kit
Project Mu titan HC+ pads (also use endless CC-R for track)
Ikeya formula traction rods
The only non japanese parts are:
2WD/4WD switch
hicas lock bar
noltec adjustable front upper arms
whiteline sway bars front and rear
generic brand alloy subframe lock collars
that's all I can think of off the top of my head but I'm sure I will have forgotten a fair bit of stuff.
oh, and I should add it would be near impossible for me to buy all parts from one japanese manufactuer as I like to modify all areas of the car and most japanese manufacturers only make parts for certain areas of modification.
Enkei NT03 wheels
BBS LM wheels
cusco castor rods
nismo engine mounts
nismo gear knob
nismo rear LSD
trust profec B II
trust hard pipe kit
trust timing belt
OS Giken twin plate
OS Giken gearset
Sard fuel rail
Defi BF oil pres
Defi BF fuel pres
Defi BF oil temp
Defi BF boost
HKS GT-SS turbos
Tomei sump baffles
Apexi Power FC
2WD/4WD switch
hicas lock bar
Now thats an impressive list, any lap times/power numbers?
what about JJR, Beer Baron?
I did have some JJR upper arms and castor rods, but switched to cusco castor rods and noltec upper arms. castor rods purely because the cusco ones use much bigger rods ends with boots and the upper arms because the JJR dog bone ones are mainly built to help people remove negative camber from overly lowered cars, since my car is not ridiculously low and I wanted more neg, not less I couldn't get enough camber out of them. went to the noltec ones which have a little more adjustment.
I do still have my JJR (well "D1 spec") quick release hub though.
bnr#, power atm is 270kwatw. lap times off the top of my head best at easter creek is 1:53.4 and oran park GP around 1:22. never had this GTR at wakefield though, and never officially timed on the Oran sth circuit (and I don't much like the sth layout). with some decent tyres and brakes I'd like a flat 1:50 at EC and a 1:20 at OP GP. It's yet to be run with the brembos, and also haven't fitted the turbos, injectors, manis etc. but happening now, should be done in a few weeks.
forgot a couple of small things:
koyo twin core radiator
cusco turbo timer (yay!!)
ganador aero mirrors
carbon intercooler duct
carbon radiator stays
carbon radiator diffuser panel
and about to order an ARC intercooler. :D
and will add a lightweight 1piece tail shaft too (either carbon one, or UAS alloy one)
oh and for seats I stuck with good ol nissan. R34 GTR seats for street and cobra evolution carbon seat with willans harness for track.
here it is in action (yes I love to whore out the pics!) :O
Lol, very nice BB, cusco turbo timer? Never heard of it, must be exclusive :worship:
lol, not very exclusive, but it is pretty damn old! it just has on/off. auto, 1 min or 3 min. that's it. it's probably 10 years old and is only there because I'm too lazy to remove it. :thumbsup:
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
MONZA
autotechnia..
lol
but seriously i think buy whatever is best in the business. like K&N filters whiteline suspension.. get the best of each group..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
