1997 Series 2 R33 GTs25T For Sale
Hey peoples up for sale is my R33 gtst.
Selling due to work commitments.
Car has been in storage since Jan 07, the boss has finally had enough i told me to get rid of it.
been in a factory, locked up and covered, car is run most mornings out to the front and back.
Loaction:- Caringbah 2229 nsw
Price:- $14 500 ono
Condition:- Good/used
Details:-
  • 1997 model series 2 GTS25T
  • 5 speed manual
  • 66xxx kms GENUINE
  • Complied
  • blue slipped (RWC)
  • Clouor coded dash fascia and gearknob
  • VOLK Challenge 17inch wheels
  • Falken tyres
  • colour coded brake calipers
  • full 3inch HKS exhaust with twin 2" tips (sublte)
  • turbosmart boost controller
  • Turbosmart boost gauge
  • Pod filter
  • stock BOV
  • suspect larger injectors
  • Brand new EXEDY heavy duty clutch
  • injectors cleaned, services (new o rings etc and flow tested to within 5%)
  • New Timing Belt, new waterpump belt, new power steering belt, new alternator belt.
  • GTR fuel pump
  • Kenwood double DIN headunit
  • just had completed service, new fluids, oil, coolant power steer, brake clutch, fuel filter, oil fitler, spark plugs, new brake pads at all corners, gearbox oil, diff oil, rocker cover gaskets)
  • new windscreen
  • new battery
  • new coolant temp sensor and clock spring (horn wasn't working)
car is always kept in top condition and well looked after its a shame to see her go but due to work commitments must sell it.
car ready to re-register, all complied and ready to go...
all the usual series 2 stuff, dual airbags ABS etc...
Just spent over $3000 on it getting it ready for sale, needs to go ASAP
**** No Reasonable Offer Refused ******
Car avaible to view at any time...
Call:-
Ryan 0417 300 656 or
pm me here or
email [email protected]
pictures here...
Edited by rizzo-xr6
https://www.sau.com.au/forums/topic/184833-r33-series-2-1997-gts25t/
siddr20 not me bro, cars been in storage since Jan 07, muct be someone else.
Cheers for the g/l anyway bro..
Will Consider any SERIOUS offers over $13 000 !!!
Edited by rizzo-xr6
  • 3 weeks later...
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
