Noticed today that the latest Wheels magazine has a tyre test. Falken FK452 came a close second to some Goodyears I think. The tyres were 17's from memory, but it confirmed my theory that the Falken's were a great tyre for the money.
the winner was most likey the one who advertise's with them most!
  • 1 month later...
  • Replies 92
anybody recommend any places that sell tyres for cheap in Sydney?
Beaurepaires in Parramatta seems abnormally expensive! I got quoted (245/45/18) 450 a corner for dunlop sports max! and my bridgestone potenzas 520!?
doesnt seem right.
yeh mate that is a big ass rort
i got my Dunlop Sport Maxx 265/30/19 for $350 each
AGR Tyres in sefton. you REALLY need to haggle them downnnn
265/30/19 is a bit too small ? is that for the rear, or are you putting it on the front ?
best one not to throw your speedo off would either be 265/35r19 or 275/35r19
  • 1 year later...
Further to my comments above, while the Falken FK452's gripped well, they don't last very long. Lasted 20,000km on the rear, including one track day. Second hand Bridgestone RE40's that had already done 15000km, have lasted another 15000km, so they definately last longer, however, they are unbelievably noisy on the front. I got out to check that they hadn't been put on the wrong way, as they sounded like the All Terrain tyres on my wife's 4wd.
Would be interested to hear of any other Tyre reports now that you have had them on for a while?
anyone tried Bridgestone RE050A or the Adrenalin?
iam using adrenalin and both thumbs up for it!...and its much better in wet and cornering compare to what i had from the dealer - Dunlop some shxt...
FYI, Costco also selling it at a really good price for 17" and 18"s~
I've got Yokohama Advan sport V103 all round. Very high grip & low wear factor but pretty quite on tarmac. I selected them out of the available "performance" tyres due to reports of their low noise. The Michelin PS2 are without doubt the winner for low road noise but are also one of the most expensive, V103 cost me $2800 for all 4 & that's as low as I could get them. If I can afford to I'd get them again.
If not I'll look at some Nitto, Vredestein or Khumo.
I had KU31s on my car, they were fine, not the grippiest tyres but also not the worst. Treadwear was OK, had too much toe-out so killed the fronts fairly quickly. In my past experiences, from a grip perspective...
Bridgestone S03 > Hankook K107 > Hankook K110 > stock tyre > Kumho KU31 > Nankang NS2
Don't ever buy Nankang NS2...they were an experiment in tight-arsedness that won't ever be repeated again.
Yep, Nankang NS-II are horrible. I couldn't wait to get rid of the set that was on my car.
Ended up with kumho KU19s on the rear, $300 each for 275/30/20. Pretty good value, i think. No problems with the grip levels (for a street tyre) and they are a fair bit quieter than the nankangs. The only issue may be tyre wear but we'll see how it goes.
  • 3 months later...
Put my silvia rims onto the v35 which had Federal 595ss (235/40/18) and they're noisy as! Nonetheless, gripped well and lasted 30,000 so far and still just under 50% tread left. Will be changing tyres I think, because I don't think I can bare the 4wd noise much longer (never realised how noisy they were in the silva!!!)...
Will go for the taller 45 tyre, but just deciding on a quiet, hard wearing tyre...
My import arrived with Yoko Decibels. Tread was down and I wanted top replace them, but with what? Did some research and spoke to some tyre places. The Yoko was quiet (hence the name) but Expensive! Ended up running with the Toyo T1R. Not quite as expensive, quiet and holds to the road well. Done 2,000Klm on them now and very happy.
For what it's worth at this late point in the thread.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
