hey guys
just wondering if any one has a wolf 3d in there 34, does it still run everything? i know they arnt plug n play, how hard is it to wire up?
or any other info on ecu;s would be great, want a ecu with no afm.
Cheers
Justin
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/
Microtech also uses no AFM if you are looking for an alternative to a WOLF3d.
Not sure who is using it in an R34, but seen a few using it in R33s.
Seem to make good power. I have a PLUG & PLAY one for sale, which plugs into RB20/25, but not sure if R34 RB25 is the same?
Have a read through the link below, you will see who is running a Wolf and what sort of power they are making.
http://www.skylinesaustralia.com/forums/in...showtopic=55845
From what I have read about WOLF universal units, they are not that complex to wire up. I am pretty sure you could get it installed and tuned for about $600?
Depends how good/confident you are with cutting ECU wires, you could probably get a wiring diagram and do it your self.
It is a standalone ECU and will run everything as your standard ECU does, besides AFM, obviously.
Edited by abu
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/#findComment-3351197
I am pretty sure on the website as well you can get a wiring diagram. I know I have an installation manual with my one which shows you how to wire it up to different cars.
Hope some of that helps a little.
Abu
Edited by abu
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/#findComment-3351206
yer i seen a few R33 with wolf and microtech, but havnt seen ne R34 GTT's.
on there site it only says R32, R33 GTST and R32, R33, R34 GTR nothing about R34 GTT.
i like the wolf cos u also get the boost controller built in(if i read corrently).
cheers for ya guys info
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/#findComment-3351284
Hi Justin,
Give Top Racing a call (08) 9472 3368, I'm sure they've already crossed this path a few times, being a premium Wolf dealer in WA.
I think the plug & play WOLF for the R33 can be used, but the base tune is not great due to the higher compression in the R34 RB25DET.
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/#findComment-3352322
  • 3 weeks later...
There is no Plug and Play for their new one, the V500, yet. If there was, I reckon I'd give it a whirl, because they look like they've got some ripper features.
the V500 uses a patch loom. it converts ur r34 plug to its own wolf plug. so u just order the correct program and patch loom and off u go. very handy if u plan to upgrade in the future, EG. should u sell ur r33 to get a r34 all u need to is put plug the stock 1 back in and order a new patch loom and a reprogram and ur off again. that way u dont have to buy another ecu to suit different plugs. cant wait to get one
https://www.sau.com.au/forums/topic/185149-wolf-in-r34/#findComment-3391311
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
