Hey guys, just a quick question,
Was thinking of getting an Apex'i Pen Style Turbo Timer for my R34 just as a small addition to the car, and a cheap first mod.
I like to do lets say, a decent amount of 'spirited' driving and thought that it might be a good idea to help preserve my stock turbo
So i just wanted to know if it is a worth while addition to a completely stock car.
Thanks,
Steve
Edited by RusH_
https://www.sau.com.au/forums/topic/185215-turbo-timer-on-a-stock-car/
I wouldnt buy one, they are a waste of time.
If you want your turbo wind down; after driving let her idle
Which is what the turbo timer does without you having to wait in the car for a couple of minutes... matter of convenience for those that drive there car more than once a week aka a daily.
And as Grant says don't boost for the last 5 mins or so of your journey. It all helps.
The idea behind a turbo timer is to extend the life of your turbo, nothing more, nothing less.
if you do it make sure its done properly. otherwise I'll have another skyline for parts..
(yes it does expose your main power and IGN wires making the car easier to steal)
since you are in brissy give me a yell. I can bury the thing - does the car have an alarm? if so then the alarm will have to be setup to work with the timer otherwise it will not arm.
Thanks to all for ur input, I would like to attempt the install myself, i've read a fair bit about it, wouldnt mind doin a lil more research, at present the car doesnt have an alarm, which i will get to, but any info on the install would be helpful, particularly R34 owners, assuming there is much of a difference between the 34 and other models
oh and i suppose not to deviate too much from my original question, but does anyone know of any good places to get a decent quality alarm system installed?
Thanks
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
