I saw someone else in this thread asking for vehicle details using the VIN for a stag, so I'm hoping I can do the same - it's NM35315451 - checkitout.com.au doesn't give me anything. It's a car I'm thinking about purchasing, and just trying to find out a little more about it before going to look.
Cheers.
Cheers.
I hope you are not in Australia Richard because that is a VQ25DD engine in that there 250RS four.
Not eligible for compliance.
Otherwise;
March '02 build
No HICAS
Cold pack option
and another option that I do not know (Code: GLSSW)
EDIT: I suppose if it was a private import that is already in the country, then you would be fine
Edited by iamhe77
Hmm that's interesting - this is the car for sale here: http://cgi.ebay.com.au/Nissan-M35-STAGEA-2...7QQcmdZViewItem
As you can see, it's listed and being sold as a turbo.
BTW what's a cold pack? I've only just discovered the Stagea in the last couple of days and I've been devouring all the info I can find as it's fired my interest.
Oops. Sorry mate, dyslexia starting to kick in :rofl:
It is a 250t RS Four
again, March '02 build
again, No HICAS
Don't know what the options are though, maybe someone here that can read Japanese can tell you.
id say wrong number
the pics are showing an RX turbo (seats have electric adjustment, plus rear facing vents in the back) but fast is showing an RS
Agreed.
Perhaps give Carizma a call to let them know that either their pics or the VIN they have listed is incorrect.
Edited by iamhe77
again, No HICAS
i meant where you confirmed the above details as an RS four, when the picture you posted clearly states RX four :rofl:
yup. go sleep mate hahah you can FAST your heart out tomorrow
I know what you meant.
What I am saying is that the details are for an 250t RS Four, but the pics are for an RX four.
We actually agree, but it seems that you are having a bit of trouble accepting this.
im lost!
i was just pointing out you wrote RS when i think you meant RX. no big deal. go sleep mate lol
BWAHAHAHAHAHAHAHAHAHAHAHAHAHA.... *sigh*
the first incorrect VIN I put in was for an RS.
(it is right about now I am so glad that my hours are extended until 6pm :rofl: )
My apologies for the confusion Richard.
no worries, I think I get the drift!
I might go check it out this weekend - anything else I should look out for while I'm there, seeing I'm a newbie to these things? Is there any easy way to tell if a particular vehicle has the side airbags installed and not just the drivers and passengers front airbags?
yup!
there will be 'airbag' or 'SRS' above where the seatbelt attaches to the B pillar. also i think on the A pillar. i cant remember........
just check the usual wear on the pedals, make sure it looks like it lines up with the amount of ks on the car. check for unusual sounds, especially in wheel bearings... also any harsh sounds coming from the turbo, hi-pitched squealing etc....
from the pics it looks clean and tidy!
again, No HICAS
Should be RX - have another look at the FAST info you attached (this is what Iain was referring to, not the pics from ebay).
Excuse me for pointing this out - it was starting to get confusing...
again, looking at the FAST info above, the VIN does in fact appear to be correct.
Yeah, thanks Steve.
I am well aware what Iain was referring to and I did realise the error of my ways - check out my post 3 above yours.
(has been a very long and rather arduous week - and it's only Wednesday!)
I mixed up the 5 and the 1 when I originally put in the VIN which caused me to site that it was a VQ25DD, this is what I was referring to.
I thought I was clear in explaining my errors. Perhaps not. Maybe Nick will delete/edit the confusing posts to make it clearer?
haha sorry cam i didnt mean to hassle you that much :)
Haha! Nah man, no sweat.
You were just trying to tell me I missed something, and then that I missed that I missed something, and then that I was ignoring that I missed that I missed something...
...and I STILL didn't catch on! :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
