When these turbos let go , is it major and the car is undrivable or can you drive it home or to your prefered w/shop ?
cheers , Lindzz
I drove mine for over 150kms no worries, although I did keep it under 2500rpm.
I believe that Jetwreck drove his from Melbourne to Sydney when his turbo let go!
They are certainly "drivable", but it is a damn slow drive.
Drove mine to R E Customs today for "turbo out" - cruised at 80 - 90 on Eastlink no worries but took a while to get to this speed - sounds awful too......
Cam, i presume the Victorian 2 are yours and mine?
Once Turbo is out i will inspect at ATP (Advanced Turbo Performance) and talk over my options.
Indeed they are Jase.
Will be interested to hear what Kip has to say (relying on my memory to remember a name from 15months ago)
Hi,
Could someone please tell me what the ARX has in terms of diffs? I want to change the oil in them using Redline Shockproof Heavyweight, is this a good option? Or what is the part number for the nissan genuine diff oil.
Is there a front diff and rear diff? Or only a central diff?
How much L does/do they hold?
Also, is anyone willing to send me copies of the latest nissan fast? $15 dollars is yours if you can.
Cheers.
  • 1 month later...
any news with this GPS english version?? Im interested! but my Screen does not work....I think there is a plug missing from the Screen to the DVD unit (small connector plug comes from the loom out of the screen is not there...)
Is there any other way to get this working yet?
cheers
michael
I have a touch screen version in process currently using the OEM screen and I'm trialing it before I do a public release.
as for the original system translation - nup do not see that happening anytime soon.
  • 1 month later...
  • 3 weeks later...
FYI for all M35 owners:
ATTESA E-TS system is normally 0:100, but can split up to 50:50. SYNC mode is constant 20:80, but can also do 50:50. SNOW mode appears to be 50:50, but hard to tell, but it does NOT start in 2nd gear. Im guessing that there is a boost limit.
ATF 'D' is reccomended, 1.8L is required to fill the system.
Diffs require 1.4L each, and factory weight is 80W-90.
Engine requires 4.8L to the H mark, 4.0L to the L mark. factory weight is 5W-30. 10,000km/1 year is the required change period.
Factory boost is 12-12.8psi.
I would agree that is where the boost stabilizes to but I still claim to see 14psi on the initial application of throttle. I may have to go to the dyno to prove this.
So the ARX does have more boost than the RS-RX...... LOL.
Edited by andy65b
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
