Any one know of some one wrecking an M35 in SA, I'm chasing a couple of interior parts...
Mike.
I saw a V35 down at the dry creek wreckers on lower churchill rd. They might have a few interior parts the same. I have a few dash parts.
Can someone here please confirm that 19" wheels by 8" offset +38will fit our m35s?
As far I as checked "yes" but it 's always good to double check...
also any issues at lowering the car with those wheels?
Cheers
Cheers
19x8" +38 offest will fit fine; but they'll look crap, miles too far inside the guards. Needs at least +30 offset with 8"width.
mine are 8.5 +20's and they sit flush i needed to roll the rear guards abit though.. but only coz im abit to low, and ARX sized tires.
So, i finally got my car down to a Nissan dealership and plugged into a Console II. (for those just joining us i have had an issue with the 4WD light staying on) The code that was spat out was C1206 which is the 4WD motor. So the issue is either with the motor its self, which is attached to the transfer case, or the wiring some where, which is a possibility as there was some other alterations to the cabling.
Mike.
the motor for the attesa system is under the boot floor on the driver's side.
Any idea what it looks like?
Is it inside the car or underneath?
I have all of the drives side side trim out to gain access to the Altessa computer so is it near by?
Mike.
No, no, the pump is under the rear (boot) section of the car... behind the rear wheel.
You can see it clearly from under the driver's side of the rear bumper.
Sorry there may be some confusion... The problem is to do with the 4WD Motor not the pump, well this is what the Console said. Are they one and the same or different parts?
same thing....there is only a 4WD ECU, transfer case, oil can and pump motor.
unless they mean the ACTUAL tranfer case at the back of the gearbox?
Well if the transfer case is entirely mechanical and clutches then it must be one of the motors under the rear of the car, would you recommend just taking it to an auto electrician to get them to see if the motor is faulty? is it something they will be able to tell?
youre right, the transfer case is only clutches and a chain drive.
the pump is where we have already mentioned. if the pump is gone, its not a cheap exercise. however it might be something easy like the attesa ECU or a relay etc.
you can hear the pump start when you start the engine. if you dont, then its something related to that.
have you checked the fluid level in the boot??
Ok I'm in the same boat.
Fluids are full.
Pump starts when I start the car, but it makes a chirping noise every 5 sec then eventual it gives up. Then I get the 4WD warning light.
thats the pump turning on and off. it will do that till it gets pressure then i believe it only turns on to maintain pressure - i could be wrong.
ok sounds like you have another problem. mine also does that, but not all the time. it may depend if im parked on a slope etc also
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
