Hey all just poppin in real quick to ask your opinions on this. I am installing a fuel pressure regulator and adjusting the level to 40 psi without vaccuum if it isn't there already. My question is do I need to take my car for a retune after I have done this?
https://www.sau.com.au/forums/topic/185641-fuel-pressure-regualator/
No you can't adjust the Fuel Pressure via the ECU, well not that i know of.
The after market Nismos have a screw attatchment i believe to adjust.
If you're using an AFC, i'm assuming your mods are on the lowish side at the moment?
Not worth worrying about.
Standard is fine as long as your injectors are pushing out enough.
People keep the standard Nissan FPR above 300rwkws.
Sorry what I meant was if he is getting the car tuned with something that controls fuel, that will increase the fuel flow, so in that sense there is no need for a after market FPR as the stock one will provide enough pressure for whatever he needs to do.
If he does't have any form of engine managment which controls fuel, which I now know he doesn't, as he only has an AFC.
You will need to get it tuned otherwise it will wont run right.
Edited by abu
as soon as you adjust the Fuel pressure, you will need a complete retune.
I don't advise this if you have a Standard ECU and Piggy back setup.
WHY wouldn't you advise this? Even if its only to make sure I have standar or a lilttle more than standard fuel pressure in the fuel lines?
Clearly, if you'd managed to set it back to the exact same base pressure your OK.
I'm not sure exact base on a R33 RB25, somewhere between 43 - 45 i believe. Like you suggest, if you don't want to find a wide band to stick up its bum, just leave the pressure a little high to be safe.
EDIT: Mafia suggested it, because if your asking the Q: then theres a chance your not aware how changing the base pressure behind an injector will effect AF ratio's through the WHOLE rev range, amongst other fundamentals. The ECU has no idea about fuel pressure so setting the pressure too low and giving your car a hit could kill it promptly... hence why you need to set it back to the orig, or a little higher to be safe.
2nd EDIT: Corrected spelling, how anyone can understand my babbling errors, ill never know :P
Edited by GeeTR
Hahah sorry what I meant was, if he is getting it tuned then fuel would be increased via tune, so in that case no need for a PFR as a piggy back ECU or after market ECU has provision to change fuel flow.
But if he is only running an AFC, then yeah they can't play with fuel.
Do you know what you are talking about? He is installing a new Fuel Pressure Regulator, not a PFsomething ECU. The ECU CANNOT control the fuel pressure behind the injector; that is controlled by a mechanical device, the FPR.
Unless the pressure being set is significantly different from standard, it would not be absolutely necessary for a re-tune.
why the hell would you bother with a FPR if you are still running the factory ECU? Whats a AFC or SAFC going to do? Bend the AFM signal, after you've upped the fuel pressure? Whats the good of that? Tell the car its running rich on the AFM and then up the fuel pressure making the car run like crap?
And you're doing this without a Wideband by the looks, which will be a disaster.
Its a COMPLETE waste of time, unless you are chasing 350rwkw or more, you have aftermarket injectors, and aftermarket ECU, and a larger turbo.
Also, the factory Injectors are madness to run with higher pressure, as they could leak, get stuck, etc, creating lean condition. Engine goes bang, and then you regret playing with something you shouldn't have been, even though it wa a complete waste of time anyway.
You haven't stated your mods, so basically you are asking us how long is a piece of string....
I am running 300rwkw WITHOUT a aftermarket FPR, all I have is a Nismo 275lph pump in the tank, nismo 555cc injectors, and a powerfc controlling them.
Sell the FPR, sell the AFC\SAFC or whatever you have, and buy a power FC.
EDIT: Mafia doesn't suggest it, because if your asking the Q: then theres a chance your not aware how changing the base pressure behind an injector will effect AF ratio's through the WHOLE rev range, amongst other fundamentals. The ECU no idea about fuel pressure so setting the pressure too low and giving your car a hit could kill it promptly... hence why you need to set it back to the orig, or a little higher to be safe.
No I wasnt thinking of setting it lower.I was just going to set it to a base line pressure of 40psi if it wasnt there already. I had the thought that if you get it back to stock or a little more than stock you should be able to get 1-3 rwkw increase. Is this correct?
No I wasnt thinking of setting it lower. I was just going to set it to a base line pressure of 40psi if it wasnt there already. I had the thought that if you get it back to stock or a little more than stock you should be able to get 1-3 rwkw increase. Is this correct?
Define "a little more" .... you mean “a little less” yah?
Technically if you leaned the motor out, yes it could make more power, but this is going to effect the whole rev range, so idle, cruise, WOT, and is highly un-recommended
I suggest, if your not doing many mods, you ditch the FPR (or if your hell bent, keep and set to close to stock base) and use your SAF to tweak the fuel accurately in the cells you want, that’s what a ECU / Piggy back is for.
As others have mentioned, if plan to make some real power, then ditch the bender, grab a PFC for $900 and use proper injector modulation to control the sized squirters of your choice.
Ok thanks man will do.Thank you all for the quick responses and advice you gave me helped out alot.
Most tuners recommend fuel pressure regulator when installing an safc or neo.
I have spoken to two very good tuners, and both recommened buying it.
Obviously you dont have to, but both tuners have said that it will aid a little and push out a bit more power..
I never really asked in depth information, as i was just inquiring about the price.
I call shananigans.
Only need to replace the FPR if your injectors run out of puff, as a cheap alternative to injector upgrades.
If they are putting thru the correct amount of fuel determined by the tune, why do you need to push harder?
Better off replacing the Pump for a good fuel supply, not the FPR.
When you are looking at Injector upgrade which is most likely..
there are the 2 options.
1) replace the injectors or 2) replace the FPR if you aren't going to much higher.
My Tuner recommened the FPR when going over the 200 towards the 250 but i still choose the injectors, cause i wanted to :thumbsup:
Afraid we are all saying pretty much the same thing :D
The one delta we don't know is because DaBoss hasn't mentioned how far he'll go with mods. A pressure bump and piggy back tune's clearly going to be cheapest.
Tuners recommend a FPR when using a bender cus its the cheapest band aid solution to get good results.
Sorry bout that usually do just forgot car is a 95 gtst current mods fmic, pod, 3.5" turbo back exhaust, ebc at 10psi lo and 13 hi and now the was thinkng of puttin a fpr in.
Afraid we are all saying pretty much the same thing :nyaanyaa:
My goal is to get around 200rwkw out of my basically stock car safely thats all I want that is the furthest I am going but, I want the most I can get out of it without changing engine internals and turbo just basically bolt on mods.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
