What a great day, strangly enough the scariest moment for the day involved my lhs steering arm falling off at 110 on the way home! ten seconds of the freakiest driving ever trying to pull a car up when both wheels are pointing in opposite directions. and the brakes dont really work when that happens...
Morwell however was a great little track, very similar to the long wang. I think everyone managed to get at least 8 runs in with a couple going the opposite direction. It was also interesting having a comentator for the whole day too, pretty funny really with the jokes he was making, especially about the doriftors in the afternoon.
Strangely enough they didnt seem to mind all the drifting. Im surprised there isnt a gemini in DA... apparently the kids loved it. and thats all that counts.
There should be a bunch of funny/good footage and photos from all our camera crews so post em up. now.
Also, thanks to all the ppl who pulled over to offer us help on the way home.
time for more beer.
https://www.sau.com.au/forums/topic/186197-morwell-shenanigans-wrap-up/
6mb Video
Here's the entire run of footage my wife took today (like 1 minutes worth!)
She has been warned for next time :P
Only shows Chris drifting, Stephen Bradford and me
Here's the link to the preliminary results.
If you see any errors or think your time is incorrect please email or PM me and I will check it.
MORWELL RESULTS SPREADSHEET
And here's some various pics :P
HeyHey
Went along for a watch today, great day with some great action on the track....
I've knocked up a few quick vids and stuck them on youtube.. they are not great quality on there but i have the originals on my pc...
Fryise's Lap
Dave's Lap
Chris in the Gemi :laughing-smiley-014:
And a quick knock together compilation of some slidewayz action from today.
Enjoy
MaT
Wow ryan! thats crazy. I've had a blow out at 100 but at least the wheel was pointing the right direction!
Glan all worked out.
Mat.
Great vids with putting together the whole lap! Have you got one of me?
Big bird, you got some good shots from that height, those and those vids are great crossy. nice music. that would go great with all the times we looped it. Russ, your car looks tuff. Mr Black
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
