  • Replies 62
I just looked at the torque figure - holy farken shit
You're making 670nm at 230rwkw at the same RPM as me.
I'm making 702nm at 300rwkw at the same RPm...
so at 300rwkw you'll make probably 150nm+ more!
going to be a f**ken monster. Goodbye tyres! ahaha
Was devastated we didn't get to wind it up... can't wait to finish it off :)
RPM Scale - This is a guide only and was done as an rpm vs road speed from the tacho.
Tuning was by no means finished, even on minimum boost, due to severe boost leaks :(
When its all finished i would love to see his dyno sheet overwritten on my RB20 graph from when we compared my RB20 with TD06 against Phils RB20 with HKS GT-RS. It looks to be making about double what i make at 3,000rpm and the little 20 doesnt catch it until 4,700rpm :thumbsup:
Hm...should i throw away the RB26 bottom end? When you get it all sorted Leigh i woudl kill to be taken for a drive in it :whistling:
Mafia,
Here's a friends old mainline dyno sheet. The car was running an XR6T turbo 1.06 rear, rb30det.
Inlet/exhaust manifolds all standard.
I believe rev cut was at 7000rpm.
Dyno roadsped appears different so no doubt a torque comparison is out of wack. :thumbsup:
Why don't dyno operators just leave it as a set value so we can all compare easily. :whistling:
Where does it make its 13psi? ~3k?
yeah roy no worries i will take u for a spin... as soon as the silicon joiners come in i will be going up to get it re tuned.. so i will keep you posted..
oh does any1 have a spare rb30 bottom end in good condition.. haha just preparing for when this one goes BOOOOOOOOOOOOOOM!!! hahaha
when i go to wind up the boost how far do you guys think i should go?? i want it a little reliable i dont want to be going through bottom ends every month... i was thinking round 17-18 psi???
Sky30's 320,000+ km RB30 held 380rwkw and prior to that 312rwkw without problems for quite some time.
Providing you don't rev it past 7k on its stock rods, motor is in good nick and tuned well it will be fine.
Rbman's currently has his stock rb30 bottom end reving to 7.3k as its holding power well to that rpm; doesn't appear to be having issues.
I have my limiter at 7k; still haven't quite got the hang of keeping it off the limiter in first and second. I recently gave the subframe 12mm rake which has improved weight transfer 2x; I can now feel the arse end slightly sitting down instead of what felt like lifting up and spinning with very little forward movement.
Go 18-20 pounds; you do have lower than 8:1 static comp so it will be fine on pulp. :D
Checking your dyno sheet, it appears that they both make approximately the same/very similar torque (and therefore power) at 115km/h.
Then the higher boosted 25 makes and holds a higher figure to generate the power recorded. Makes sense really, with power being a function of torque and rpm. Wait until this 30 gets fed a bigger mass (via boost) and hopefully gets some bump sticks that allow it to breathe more effectively. Even if rpm is governed to less than 7k, it will make some pretty good grunt.
If the current peak power rpm @ ~5300 is anything of an indicator, the torque will be stupendous.
Dyno roadsped appears different so no doubt a torque comparison is out of wack. :(
Why don't dyno operators just leave it as a set value so we can all compare easily. :(
What's the difference attributable to? Hasty setup and calibration by the operator, or some real difference in gearing ie. tyres, final drive or gear ratios? If it's a 32 chassis, is it still running a 25DE spec final drive?
Some times it's very good to review the graphs using both engine and road speed. I have an old chart from my bike being dynoed through the gears, before/after final drive alterations. The amount of extra grunt hitting the road in any gear, at any sane speed was significant. :(
Its an R32 chassis.. Setup by the operator is what the problem is.
Mine making its peak power at 6k with basically the same turbo is starting to make me think getting a little head work and port matching done is most definitely worth its while. Can't wait to get the lumpy 805c grinds in to it. :(
...wow was lucky enough to have a ride in this weapon yesterday, the torque is absolutely unbelievable. Having basically no traction till 4th is definitely a thrill too. Congratulations Leigh, absolutely siked for you!
18-20 pounds it is.. haha
That's great, congrats!
I am thinking of doing the same in my 34. Where'd you buy the motor from or did u have a VL/R31 for parts?
Cheers.
i just bought a rb30 off a mate for $100..
Out of interest, did you do any timing belt tensioner re-locations, and which timing belt did you use?
yeah i bassically just followed the rb30det guied in cubes sig...
did you use fresh rings or just grab the bottom end and bolt it up?
no freshen up just a bog stock bottom end with the head bolted on top.. just as GTST says...
thanks guys for all the coments!!! just heard the silicon joiners are in the mail so hopefully they wont take too much longer..
hey just a quick question..just say u had a 32 gts4 or a gtr and u wanted to do the rb30 bottom end with rb26 head would u be able to keep the awd(atessa) in?
would it fit or would u have to remove it??
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
