everyone knows how horrid the r34 gtt stock gauges are so im about to replace them with a set of defi gauges. if i purchased another 2 i would get a good deal.
so the question is, what 5 gauges should i get? i understand that boost, water pressure, oil pressure, exhaust temp, manifold pressure are popular ones.
basically what 5 gauges would u set up in your car if u had the chance
Edited by R34NRG
https://www.sau.com.au/forums/topic/186440-defi-gauges/
Ive got defi's for my r34gtt - boost / water temp / oil pressure / oil temp / big defi tacho with shift light
only other one im looking at getting is exhaust temp....helps you know when your about to melt things :domokun:
have u got any pics mate? would love to see em!!!!
wat colours did u get?
me personally am going for the red set
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370313
1. PSSSHT value
2. CHUCHUCHUCHU-meter
3. +40PSI reading boost meter
4. 8"-12" monster tacho
you know me, id get em if i could :domokun:
do we have any SAU traders that sell defi guages?
would like to compare prices
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370336
havent fitted them yet to the r34 yet took them out of my ceff when i sold it and now i have the r34 i'll whack them in when i get some time (and a sandwhich plate)
i went the white black outs exept for the tacho its the other version as they didnt make a black out tacho (bugger)
got them through cj motors off the silvia forums he's in brisbane and super fast turn around for stock...i highly recomend him.
apparently the exhaust temp will also give you a hint as to when stuffs leaning out...or so ive been told by a few workshops so im looking into sourcing one before i install the rest of the set..
be sure to post pics when its done man!!!
they been going for around the $215 mark but ive seen some for $250.
how much did this brissey guy give em to ya 4
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3370357
I have,
Oil temp
Oil pressure
Water temp
Exhaust temp
Fuel pressure
Turbo
5 mounted in the centre part where air cond stereo etc used to be
and near the a pillar
you've also got to mount the control box somewhere too. so keep that in mind!
but this is in a 32 gtr
Edited by Angus Smart
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371362
im not a expert but could someone explain why oil pressure would be more importent then......lets say for arguments sake manifold press?
just to get a better understanding of what my setup on my type of driving could be suited for
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371579
manifold pressure would be quiet similar to boost pressure/turbo... (i think)
oil pressure is probably the most importiant out of the lot, without pressure how are your internals going to survive!!
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371604
Because low oil pressure is a hell of a lot more pressing problem than low manifold pressure and indicates a serious problem such as oil pump failure, oil surge etc. Something you'd be really keen to playback after a hot lap.
Besides the manifold pressure gauge is for a NA car if i am not mistaken.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371619
Horrid? Nope. I think they aren't bad for stock gauges unless you are aiming to impress Paul and Vin when V-tec kicks in yo.
Admittedly I've upgraded to the Nismo gauges but hey, they work.
I'd like to see -
1. Dose/flutter meter
2. KM's to Noble Park Macca's
3. RPM till V-tec kicks in yo
4. $ left till I've payed the car off
and last
5. Number of Bush cops I've noted on the way to Noble Park Macca's
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371650
Because you car's blood is oil, no oil = dead engine. Low oil pressure = problems so it's nice to know what's going on.
Manifold pressure means nothing unless your floor pan falls out when you exceed it's limit, most likely from too many NOS shots.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371664
If your oil pressure has dropped off, the damage is already done.
Especially @ 7000rpm. IMO the oil pressure isnt that much of a help (over the stocker gauge). As ye, once you've done your dinner... thats it.
https://www.sau.com.au/forums/topic/186440-defi-gauges/#findComment-3371668
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
