  • Replies 138
also check ur intercooler hoses, i once had a cracked (not visible) cooler hose, the ones going into the end tanks that stopped my car from holding boost coz it wud split slightly on high boost. other then that u said u have changed plenum seals etc... i dunno maybe turbo or actuator
yeh but wat did they check wen they say "boost leak check"?? i mean its easy to miss something... doesit sound like it has an exhaust leak? maybe turbo gasket (between exhaust manifold and turbo)?
hmm i dunno, i guess u need to try rule out a few things, may be a leaking BOV issue, i mean u are still running the stock BOV yeh? try borrowing one see if that helps
Edited by mass_iv
ive changed it to an atmo one and was still doin it.
now ive modded my stock one... read up abit..page 6 i think.
i even blocked it off all together with a coke can lol... still the same
Edited by R33GOD
this was with the leakin plenum gasket.
previously i made 241 on the same boost a week ago. but yea couldnt hold 16 psi this time either
Some tuners do not know how to fit a boost controller in...trust me.
You will need to re-set your boost controller.
This is what happened to my AVCR...after a few weeks I lost power and boost.
Anyway...you may need to take it to another tuner for more in-sight into whats going wrong.
Hope I have been of some help.
the boost controller has been in for a while.... we'll see how it goes next week, hopefully they can sort it out
Question: What if you squash the Unit, without blocking the hole.?
As I need to make it so It does not release air back thru to the plumb back pipe, say when ur driving at -10 psi. or backing off the throttle from -0 pressure gentley .. this condeluded pipe is pissin me off! I can hear any volume of air, passing thru the Pllumb back pipe, + pressure or - pressure.
Edited by silverbulletR33
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
