Hey Mexicans I dont speak spanish so I will keep it simple :thumbsup:
I and a few others are making the trip down again for DECA just want to give you a heads up as it seems that some where very upset that we where better then most! :(
But I am bringing my car this time ( SMOKY WONT LET ME DRIVE HIS NOW )
But dont be intimidated from our driving experience we wont hold it against you :)
But on a sad note stevo has informed me that since he can not handle his grog he will not be attending this final event actually it may be a good thing NO POOPRA will be there YAH!
bla bla bla will post more crap on here later!
:mellow:
https://www.sau.com.au/forums/topic/186832-final-deca-for-2007/
  • Replies 103
Oh seriously if anyone has been from Vic has a Digital camera and I guess there wont be allot I would love them to take some good photos for me as I will put together an artical for HPI no pormisies that it will be in it but I will do my best. :thumbsup:
Andrew - will send you accommodation details via PM.
Ill leave it to you to let any other who are definately coming down to book.
Accommodation is different this time as most of Shepperton is fully booked, so if your coming, I'd suggest booking something ASAP.
Cheers
B
Is this for the event or are you talking about something else?
Help to speak CLEAR English :(:)
surely there's a way to remove your thread starting privileges...
attack this
-thread moved - pointless
Help to speak CLEAR English :yes::P
I was trying to speak mexican sorry ! I was unaware that there are many of you that can read english correctly LOL :O
Unfort I will be not making this trip down, so someone else will have to go for first place in the NSW team, pitty I cant make it third time lucky :)
Good luck to all the other NSW members
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
