Damn str8!
..so tight, if stuck a lump of coal up there, in 2 weeks it would be a diamond.
Now, where are those scans?
that friggin tight i cant even fart sorry guys no skanna u gunna have to do wot i did and b b b b buy it.or cum ova and ill let u look for a buk
https://www.sau.com.au/forums/topic/187190-congrats/#findComment-3384923
Yep, good job to Brendan for winning the best Stagea award on the day! It was very well deserved, even though ALL of the Stageas there were well presented (except mine, I was so busy leading up to the event and helping out on the day that I didn't get time to detail or even wash my car!)
More information is here, and the article was very well written by one of our own here at SAU - Andrew "nuttsHunglow" Hearne. Quite a number of the photos were taken by SAU people as well.
https://www.sau.com.au/forums/topic/187190-congrats/#findComment-3386352
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
