ok when im idling and i turn on my air con, the car revs up to 1500rpm, then drops to 700rpm like it does that quick goes up and down up and down until i turn it off or wait until it settles down, which it does after a while, also its only blowing hot air now (could need a re-gas, but that was done only just a year ago how come its gone so quick), and sometimes when i press mode to skip through where i want air blowing it makes a clicking sound loud and for atleast 30 seconds, heater works good though, although last time i used my a/c was back in april lol and thats when every time i used the a/c the gears were hard to get into, especially 1 and reverse LOL
someone help ^_^ stupid climate control
https://www.sau.com.au/forums/topic/187370-air-con-disease/
There is a diagnostic check that you can run to tell what the problem is.....
Start car and hold down the OFF button for 5 seconds and it will go into diagnostics mode.....
It will then show you any error codes.
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3382107
Probably just coincidence that the gear selection is awkward when A/C on.
The ECU will raise the idle revs when it gets the signal that the A/C is operating. The hunting for idle is probably the AAC valve.
Try holding the "cold" button until the unit displays "FC" (full cold) - does it still blow hot?
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3382290
What's it mean if all the lights light up. all good or all bad.
BTW where do you find all these diagnostic tests?
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3382719
Try holding the "cold" buton until the unit displays "FC" (full cold) - does it still blow hot?
so i started the car and held the off button but nothing happened LOL wtf!! cold button? the blue one? its down to 18c but still hot as, sux coz its getting real hot nowadays + i cant believe it needs a regas so quick!!
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3383432
It could be a leak in your system or you've got a stuffed motor (motor which controls the hot/cold). First thing is try the diagnosis to see what's going on before ripping out your dash.
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3384251
it doesnt want to go into diagnostic mode? :S the clicking isnt normal, as it never happened until recently :) damn ripping out the dash.....oh well perfect time to install some gauges etc etc, i'll try a regas 1st then see what happens, if theres a leak in the system how do i go about fixing that, can it be a diy? or needs to be done professionally
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3386433
it doesnt want to go into diagnostic mode? :S the clicking isnt normal, as it never happened until recently :D damn ripping out the dash.....oh well perfect time to install some gauges etc etc, i'll try a regas 1st then see what happens, if theres a leak in the system how do i go about fixing that, can it be a diy? or needs to be done professionally
If the car is more than 5 years old the rubber hoses were made to handle R12 refrigerant - the cocktail of gas used now is molecularly smaller and will weep through the pores in the hose - common thing - if you re-gas it will slowly deplete again, only way out is to try and get some R12 - but i doubt if you will. The hoses have to be replaced.The reason it is hunting is because oh the LP switch sensing a drop in pressure and the compressor clutch is comming in and out. sorry
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3386559
it doesnt want to go into diagnostic mode? :S the clicking isnt normal, as it never happened until recently ;) damn ripping out the dash.....oh well perfect time to install some gauges etc etc, i'll try a regas 1st then see what happens, if theres a leak in the system how do i go about fixing that, can it be a diy? or needs to be done professionally
The clicking noise is worn out gears. The gears which move your vent direction is worn out and the motor slips while trying to turn it.
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3387219
yeah same, stupid aircon fan, errm expensive to replace these gears? motor or whatever? how about the hoses? its too bloody hot :) dont even feel like smoking coz its so hot, how about the problem with my gearbox? like it only happens when i turn the aircon on (cold) on heater its fine, once i couldnt get into any gears it would crunch even when i was at a stand still, but if i gave it a rest and came back few hours later would be fine, hence the reason i havent used my aircon for ages lol, try parking without being able to get into gear :P
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3388401
That idle up then down is the clutch engaging the aircon compressor, which increases the load on the engine, and the AAC valve increases your idle to compensate so it doesnt stall. The drop down occurs when your thermostat is at the correct temperature and the clutch is disengaged from the compressor. Perfectly normal unless the Aircon switches aint working. The clicking sounds can also be the vents opening and closing, its a common problem apparently, the little plastic teeth come off the rails so im told??? but requires the whole dash to come apart - stuff that
I dont think the size of the molecule matters witht the aircon hose, I think its more the press fittings which are the issue, or any threaded joints especially if youve been moving/bending aircon pipes/hoses about the place to get your FMIC to fit. Take it to an aircon place, they inject a die into the cooling system to check for leaks, make sure you tell them o/wise theyll just fill it up and send you on your way - they love it, cos you come back in six months to get the same thing done. O/wise keep the windows down and make sure your heaters turned up - problem solved :D
https://www.sau.com.au/forums/topic/187370-air-con-disease/#findComment-3392553
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
