Hi guys, i recently purchased a 1996 s2 r33 gts-t. Im soon to be installing a aftermarket FMIC (proberly Just Jap).
Can any guys who have installed a intercooler kit who have a stock series 2 front bar please write up or show pictures (woulb be better) of what had to be cut, moved or removed completly.
Thankyou
p.s. please no chit chat, just info and other helpful tips or pictures. :D
https://www.sau.com.au/forums/topic/187466-r33-intercooler-installation/
You will have to cut the black plastic bit out of the mouth of the front bar.Cut a hole under your washer bottle for the pipe to come through.But if i were you i would get a dump/front pipe before doing an intercooler.
search the tutorial forum section, theres a guide for the ARC kit (the one that pipes into stock positions, pipe pulls a 180 on the cold side and loops back underneath) and also one for the Hybrid (similar to Just Jap kit) so just search around. From memory though the Just Jap ones require trimming of the fan blades, cutting under washer bottle and trimming of the front reo bar.
heres a guide to where you'll need to cut the hole, under the washer bottle that i ripped from the other thread:
you'll need to cut out the front reo bar in 2 places for the fmic to fit up to 2 existing holes on it (you'll see them when you take the bar off).
ive seen plenty of s2 installs that dont need the front bar to be hacked into with the JJ kits.
its the series 1 bars that need butchering.
I noticed there are two small items i think they are the horns in front of the radiator behind the front bar, do they need to be relocated? does the bar behind the front bar need to be cut to fit the cooler or compeltly removed?
I did look at the two guides, they wernt much help. The Arc kit guide was great, but im not using that kit, so i need to now for a JJ kit. Does the washer bottle need to be re-located? dose the front intrusion bar need to be cut into or removed altogether.
If you cna find any other links for install. please put them up :D
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan and front bar lights instead eek!
Edited by SevenAngryPenguins
Got any pics of it all installed? wot did u do with ur washer fluid bottle?
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan instead eek!
I installed the JJ kit on my s2. No trimming of fan or moving horns. Have to cut the centre section of bar out, a little out of sides of bar to allow room for pipes and cut a little bit of plastic bracket off washer bottle if you have to. I also got my mate to weld on a nipple for the boost line. Quite simple, just take your time cutting the front bar as you don't want to cut too much at once. I'm happy with the kit, looks awesome! :blink:
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
