after buying 2 radiators to sort some overheating issues i was having
1st was a china job ebay (s13, leaking from the top neck, 20 bux to fix), worked well looked shocking (welds ect)
2nd was china ( r33 worked well but was a prick to fit)
my last car i finally found a china radiator that works a treat and the quality is top noch
anyway they are 50mm welding is tops
no bs good radiator and they fit!
anyway 250 will grab ya one he does them for s13/r32/r33
has them in stock and ready to roll
anyway generally its 30 bux for delivery
anyway i think they are a good thing and they are cheap if anyone wants on
flick us a pm with you man and address and details
drop us the cash and radiator is yours
money details
account mane: peter carruthers
BSB: 112879
account number: 428965807
note i dont make any money out of this i jus though it was a good price
https://www.sau.com.au/forums/topic/187748-50mm-alloy-radiator/
  • Replies 285
Hey Fatz,
Been looking at getting an alloy rad for a while now.. great price!
Do these retain the factory piping?
Who is the Manufacturer?
Anything else required for fitment?
Cheers,
Johno
Hey Fatz,
Cheers,
Johno
factory piping!
manufacturer (china)
anything else not that i know off but the r33 one needs an extra washer to space out the temp sensor (purchased at bunnings for 5 cents)
couple of answers
delivery is a few days if your in sydney
maybe a week anywhere else
these are in australia
s13 i ran thermo fans on (it was a rb30 in the s13)
the cores are duel core (the cores themselves are twice the length of the stock cores.. so the cores are twice the standard nissan size)
supplier is a mate of mine
taking the fan off is the same as a stock core (flexible hands help)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
