just picked up a oil cooler kit form the supplier
they are shit hot
might do a group buy on that toooo
picks soon!
cheers
fatz!
let me know if this goes ahead soon as i'd be very keen and very soon!
  • Replies 285
Any 32 ones left in stock? Ive got a track day on next sunday and i'd like a decent rad in the car to ward off temps... If they are in stock would i receive one before friday of next week (in adelaide)
when i received the rad i was rapped! but i fitted it (didnt put any coolant in it) and found you sent me the wrong radiator.. i asked for a R33 one and received an R32 one.. fatz.. pm me or ring me ASAP to sort this out..
THERE ARE NO SR20 RADS AVAILABLE - EVER
all nissan radiators are $299 delivered accross the country, same fee, of $280 pick up
R32 and Ca s13 sizes are 380x648x32 manual only
so has anyone measured their cores yet? R33 are 45mm. you should change the title of your first post dude
And yes s14/15 are avaiable and in stock, they also do WRX, RX2-7, falcons, commodores, and a universal 370x638x50 with 2 inlets, 2 outlets +block off plates
Edited by cazman
Hey !
Just what im looking for ! .. My stock one is starting to corrode at the front... so need to start to look for a new one!
Have you got any for an R33 in stock?
Let me know soon!
Cheers!
Anyone here installed one into a r33? Is it as simple as changing with a stock one?
Edited by br3ndan
pics as promised:-
The brown Wire in the 2nd picture... this is the earthing cable?
With the copper washer.. i can just pick then up from say bunnings and its for the thermo stat??
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
