Just for your info, the series 2 does not have the sensor in the same spot as the series 1. I did not have to relocate it for the manual conversion.
There are a few cars getting wrecked on the forum, so it should not be too hard to find a cheap one.
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3392540
hey guys i may be wrong but every g sensor i have seen in cars under the concole is for the air bags. as i have replaced alot under warranty on new cars . but i may be wrong just putting the thought out there incase it helps.
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3393117
Yeah there is an airbag one in the same area with lots of warning signs on it and yellow wiring running out of it. G-sensor would need to be facing in the "factory direction" so that it can tell if the rear of the car is stepping out, not sure what signal it would be getting if it was sitting sideways?
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3393222
yeah turning it 90o is not good for it, the lateral and longitudinal g sensors are seperate and it will think you are turning when you are accelerating etc.
Of course it might make the attessa perform better (per the autospeed article years ago) but i doubt it relates to the xfer case dying.
Nick good spot for the sensor I might move mine there....mine is further back between the handbrake and the console bin but it is a very poor fit
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3393383
As far as I can remember, the airbag one is the one right at the back in the last of those pics I posted. I'm not sure if it's a g-sensor or just the triggering device, or maybe both are in the same unit.
Here's another pic of it:
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3393667
Yeah lousy torx bolts, had to buy a socket to install the handbrake.
I don't do too much rally driving, so hopefully the G-sensor doesn't take too much of a beating from my turning it 90 degrees. I will endeavour to turn it back now that I understand its purpose better. I'm driving my car full of gear with a trailer to Bathurst tomorrow, so I'll be taking it nice and easy. It's a very easy way to lower your car by loading it with about 500kg of stuff.
When I get to Bathurst I'll turn it around for the homeward journey.
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-3393708
  • 3 years later...
  • 10 years later...
Did turning g-sensor to factory position help?
https://www.sau.com.au/forums/topic/187818-g-sensor/page/2/#findComment-7968461
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
