all looks good so far :P will you be recovering the dash, after you've fiber glassed the extras, with anything (vinyl, fleece, paint) ?
Tell me what you think..
I took the dash from my Bayside Blue crashed parts car, and now making my own custom modified / fiberglass'd Dash board.
From the pictures I hope you can see where im going with it.
DAY 1
.....section removed.....
Dash cleaned and degreased
general look will be like this:
  • Replies 241
Posted Images
all looks good so far ;) will you be recovering the dash, after you've fiber glassed the extras, with anything (vinyl, fleece, paint) ?
Yes either leather or Suede.
It will be alot work still
well the price would probably be alot more if I told them to hurry up, and focus this as their only project until its done. but bumps in the road happen, and things go on a standstill while new parts must be ordered to make the install as seemless and OEM as possible.
my new website will be online once the car is completed WWW.MWR34.COM
it will be the home of the complete build gallery, the photoshoot gallery, details of car, also this car will be for sale.
And future build plans for your custom-made MWR34 will be available. lets hope this turns out nice.
the car will be for sale? why do that? build it up then sell it :D awesome build up, takes someone real dedication and a clear view of what they want to do something like this :)
the car will be for sale? why do that? build it up then sell it :domokun: awesome build up, takes someone real dedication and a clear view of what they want to do something like this :P
Thanks, this car has consumed most of my free time for the past two years.
I believe im the only r32 with a front and rear conversion in the world, and haha trying to show the world what i can do.
and Yes I am on cardomain http://www.cardomain.com/ride/3129276
  • 1 month later...
  • 3 weeks later...
found my gas door
and my OEM third brake light
mounted my taillights to the car and test fitting the position of the spoiler
HOTTTT
And just so everyone knows, the trunk cannot close yet, thats just the weight of the spoiler keeping it almost shut. fits flush thou:):):):)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
