Riceosaurus Rex
ricer-48377.jpg Any oriental import car that has been modified for no real performance gain.
Ricer: An oriental car with no engine mods, a body kit, and possibly stickers. Made to look fast.
Not a ricer: An oriental car with a fully built engine, drive train, and suspension reguardless of appearance
I saw this! Great term for a car.
RICER OR RICE CAR.
What you think?
https://www.sau.com.au/forums/topic/188100-riceosaurus-rex/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
