Riceosaurus Rex
ricer-48377.jpg Any oriental import car that has been modified for no real performance gain.
Ricer: An oriental car with no engine mods, a body kit, and possibly stickers. Made to look fast.
Not a ricer: An oriental car with a fully built engine, drive train, and suspension reguardless of appearance
I saw this! Great term for a car.
RICER OR RICE CAR.
What you think?
https://www.sau.com.au/forums/topic/188100-riceosaurus-rex/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
