hey guys,
iv got 3 broken manifold studs that need to come out, iv already tried to get them out but dont want to go any further because of the risk of damaging the head
so just wondering does any one know of a mobile thread guy that will come out and do it?
any help would be great :)
sam
https://www.sau.com.au/forums/topic/188118-mobile-thread-guys/
how did you try get them out ???
did you drill through the stud then use an easyout?
thats the easiest way to get them out
oh and put a lil bit of heat around them with an oxy torch can loosen them up a bit
To get broken studs out if you can tack a piece of metal to it and then just undo it. I understand that it may not be possible without the room to do it or if the stud is too deep in. Just an idea that worked for me
iv found a mobile thread repair service
"peter whitefoot thread repairs", says he does broken studs and re thread etc so ill give him a call tomorrow :(
hopefully he can get it done then i can get the manifold back on, then the new turbo, then s15 injectors, then pfc with z32 afm............
then hopefully my car will be faster than brads (RDIRTY3's) car which will put me at rest :)
Edited by sam5709
"peter whitefoot thread repairs", says he does broken studs and re thread etc so ill give him a call tomorrow :)
then hopefully my car will be faster than brads (RDIRTY3's) car which will put me at rest :O
did you source a pfc? if not shot me a pm! exchange rate is high! and there is a few for sale :thumbsup:
then hopefully my car will be faster than brads (RDIRTY3's) car which will put me at rest :thumbsup:
Until you f**k around with it again and blow it up for good! You may go faster, but ill still be driving while your walking :)
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
