I haven't taken my car to the track yet and i am just woundering what pads i should use.
i would just be putting them in driving to the track going for a run and taking the pads out again once i got home.
I have a solid (vented)front rotor and drilled rears. I will get slotted rotters for the car in time but untill then i will stay with the setup the last owner had.
Its a r32 GTR.
Also after the best tyres for the track and where to get them?
and can you run semi slicks on just the wakefield licence.
Cheers
Keith
Edited by BNR32t
https://www.sau.com.au/forums/topic/188200-brake-pads-for-the-track/
Its a r32 GTR.
Cheers
Keith
I will probably be going for the EBC red's for everyday use and track (designd for the track as they need to heat up to be most effective). Are you looking at changing the rotors as well? You normally let the pads bed in to the rotors and swapping and changing them would seem to limit their effectiveness.
I'm still considering tyres, Ladybytes swears by here Federal 595 RS's.
The wakefield licence allows you to run full slicks if you want.
I just had these installed last week along with some new RDA rotors. You're sure as hell right in that they need to be warmed up to be at their best.
I've got EBC reds. Yep you need to dig into them a bit when not really warm to stop fast. I'm very happy with their stopping power in general in combination with my RDA front slotted rotors and about to try them on the track. They are half worn already, so we'll see :( My mechanic says the EBC Greens are even more track oriented and need to be warmed up even more!
Edited by sl33py
Your mechanic is wrong then :( the greens are a "performance" steet pad. the EBC Red's are more of a "high performance" street/Track. I ran RB74's on wakefield and although some people say they are not as good as some other brands when you way up the $$$ vs performance i thought they did bloody well, no break fade or anything like that
They still break as well as ordinary pads when cold? Just lots better when warm?
It normally takes 500km to get the pads and the rotors to bond most effectively. Hopefully it will improve over time?
Yeah hopefully they eventually stop squealing loud enough to wake the dead after 500kms!
What are the ferodo's like everyday?
Or are they just a track pad?
im still using them on my car and they've been on the car for a year and a half! (done 3 full track days on them). they are great on the street. they take about 2-3 normal braking applications to warm up and work effectively, but once you've done that, they're perfect. as an everyday pad, i would recommend them.
as for the track, they are also great. they can handle big temps and wont fade (in my experience anyway). i warped my brake discs before my brakes faded, then my fluid boiled, but the pads stayed true and still to this day will stop my car on a dime....
will is ds2500 the part number? Will they go straite into my r32 standard rotors? Or will i need a different part number?
Cheers Frink, Cause i work at repco and we sell ferodo's so it might be a cheap option for me.
thanks heaps mate.
For Brakes I would go for Bendix Ultimate, they're great for everyday driving, takes about 2 good stops for them to get good "bite", I used them at Texikhana recently and had no fade, sqeal, grinding or excess heat... They were great.
For tyres - street legal semi slicks go for Federal 595RS, best bang for your buck tyre available.
thanks heaps mate.
they should do straight in the rotor, they do for 33's. you should be able to research the part number in the cataloge you should have behind the desk (im only guessing...). they are more expensive then the Bendix Ultimates, but i think its worth it....
its funny, just as i say all these good things about these pads, only this morning they ran out pad and i now need new ones! oh well, they're still a great pad....
I'm now considering EBC yellows, better in all ways to the reds except for dust. Not so sure on the quietness though, they don't advertise that.
Considering I can land a full set (F+R) for the GTR for $330, that is a huge saving.
you will find the EBC yellows are more of a track pad than the reds, if its for everyday street use even EBC recommend against going the yellows over the reds.
edit: makes more sense now.
Edited by TiTAN
EBC says:
Ultra high friction pads for race use but perfectly safe for street use (Formula 1846).
Although a full race material and capable of high temperature use with very good wear life, this new formulation sets a new trend in race type brake pad compounds that can be used on the highway. The “bite” from cold is superb which is uncommon with race materials (normally requiring warm-up) and makes this a pad which can be safely used on both street and track. This new formulation has been used by numerous championship race and rally drivers and is truly a milestone in brake pad material development. Nominal friction coefficient 0.5 with zero rotor damage and similar dust to original pads.
http://www.ebcbrakes.com/yellowstuffinfo.html
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
