cheers guys.only my second rb build at home.. spec wise..
rb30 block, bored for cp forgies,spool rods, acid dipped, new welsh plugs
crank polished and balanced with rb26 front pulley fitted
acl bearings, arp main/rod & head studs
n1 oil/water pumps, trust big sump conversion
rb26 head, jun 264/in 272/ex with 9.7mm lift.
tomei pulleys.
twin tomei intank pumps, feedind either end of the fuel rail (home made again).
hks fuel reg and 10 row fuel cooler.
denso 720cc inj.
exedy triple plate clutch.
uk,s first extreme turbo manifold kit for an rb26/30,with gt35r and 1,06 rear. tial 44mm waste.
4" dump pipe ( home made ) with screamer plumbed back into dump.
and i hope to get 650bhp @ the fly and some serious torque...
bernie.uk
Edited by rockabilly
nearly there guys, put the trust sump on filled with oil and it leaks from a weld so its of at the moment being cleaned and rewelded, should be back mon tues next week. then in she goes.
the silver shit aint too good with high continuous heat...however the high temp black seems to handle it the best.
Our dump pipe was originally done in the silver ceramic coating....two race meetings and it was gone. I would hate to see what happens to it on a manifold.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
