wtf is it with people taking pictures of my car with their frikin mobile phones when they are behind me???? geeezzzzzzzz .......................
does ne one else have this trouble?
You wonder why people take photo's of your car when you have specifically done it up to look snazzy and be entered in comps.
I'll let you think about it.
ok i need the bottom lip of my front bar screwed back in and im thinking i could just as easily take it to my mechanic but he might not have the same screws that a bodykit shop would have
so heres the question where in a close radius to the CBD do i take it too to have a quick look see and screw a screw :(
hey i hear what your saying but i just dont see the car being that snazzy, espcially when there are better street driven cars out their that are more flashier than mine.
oh and madaz use super glue....................thats what is holding the side of one of my eye lids down at the moment.........its doing quite a good job too :O
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
