yeah the bikies do some kind of charity cruise too.
i hate car thieves. which brings me to my question
If cops know that there is a gang doing bad stuff, why dont they have the power to just f*ck them over? why dont they have the power to stop them getting the dole, stop them getting car rego, u know just stop them from being able to do anything at all if they are KNOWN to be involved in a gang that does illegal activities?
that would seriously stop some gangs.
If your talking about gang of 49, some live at richmond not sure on the name of the street but its before knight street. I used to work the street behind them and was good mates with the ppl living right behind them and they used to get cops asking them questions and watching the street all the time. Cops have been doing somthing about it but still it wont end for a long time.
because you then turn into America and end up with more violence then what your trying to prevent heard of 3 strikes and your out still doesn't stop people committing crimes
grabn a r34 Power fc to utilise it all a bit better
going well tho thats for sure
2yrs or so down the track I'll grab some 480cc's and a gt-ss I reckon, but till then will enjoy the Slide unit
lol. Probably because if the cops took all that away they would have more reason to steal. If i was a deadbeat on the dole and it was taken away from me i'd either have to get a job or steal. Now being a deadbeat i'm not going to get a job so i'll just steal more.
The police really can't do that much, it's more of a social issue than anything.
hahaha all good... i just take it thats at the spare wheel then
lol LMAO
nice little miss, nice
Sam, yeah either that (hks gt-rs) or the 2835pros kit one day
hey, who can help me with this?
I can really say I understand it =(
when I get my Pfc I wouldnt mind if someone could help me wire this up.
or should I go to an auto electrician ?
Tangles: That would be very easy to do. Its just a couple of electronics with the +ve feed coming from the ignition (just need to find an ignition +ve) through the components with the diode wired in the right direction, and connected to pin54 and grounded through the resistor.
If you get the parts from Dick Smith or Jaycar, I can help you wire it up if you want on a saturday or sunday :(
cheers, still goobly gook to me tho
lmao
yeah I'll have everything at hand when its ready to go (gotta get the pfc first, and have a date booked for tune)
damn radiator busted itself again.
this year Ive had 1 replacement radiator, replacement water pump (wasnt done at 100,000km service 2yrs ago, although I paid for it), and now the radiator again.
hoping its a hose
any good pressure testers / radiator workers in the city ??
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
