another thing is isnt it legal to have nos jus for show in the car aslong as its not hooked up? and even if its not how easy would it be to pull the nos out n in again compared to any other mod like turbo n supercharging
Edited by gzilla
I don't see what so unique about spending money on an NA skyline? or any skyline for that matter? there is at least 15 million of them on australian roads.
Modifying Commondores aint unique also... theres 11ty billion of them on Australian roads - half of them have sick chromies, V8 supercar spec loud zorst, frosted/clear tail lights and massively dumped. :banana:
Myself, I spend money on the Skyline purely for the enjoyment of modifying it to how I want. Not to be unique but to my satisfaction.
my mums has a tissue box n lawn bowls hat in the back parcel shelf aswell as disabled parking permit in the front :( gives ya street cred with the grannies
couldnt stop laughing when i had to drive it and a fellow vp driver gave me a head of respect or something :banana:
hey at least ya can get the good parking spots :banana:
no its illegal in every way. touch wood nothing ever happens.
i found out i can be defected for just having the lines in there because it still classified as "intent of use" or whatever it is. :banana: and i mean how many times would the police have heard "oh no officer its only for track i would never use it on the street" and then catch the same person using it on the street? makes it hard for people like me who are being honest, and would never use it on the street.
my mums has a tissue box n lawn bowls hat in the back parcel shelf aswell as disabled parking permit in the front :)gives ya street cred with the grannies
rofl....Street Cred with the grannies eh...........I'll have to remember that one :(
i just drag my leg along when im leaving the car so no 1 asks questions :D no not really for any one buying my bs
hey ya dont even have to do that, on the stickers it says check the sticker not the driver. i saw one on the rear window of this old ladies camry,
MissR34,
I still don't believe doing the NOS thing is a smart mod as the outlay + bottle refills + the risk of fines + easily being defected + the lack of practicality at mallala (no AIR) simply is not worth the hassle to try something different.
I genuinely do hope the overall look of your car doesn't attract the police enough for them to pop the hood and find that nos kit. With police who cruise these forums do be carefull posting pics of your car so it doesn't become known.
If you do end up going ahead with it.. Don't be weak go with a 200hp dry kit; John loves his autronic ecu's which will handle it fine with a set of larger injectors. But as with anything if you want it to be reliable and make it worth the risk you will have to spend the $$.
Once you get a little power under that foot you will want more. If you are starting to venture in to the power arena consider building the car with a little more power head room just incase; power is addictive and its fun. Most who go there almost always want more.
You don't need to get narky with me as I'm only speaking the truth and definitely not digging at you but rather slightly concerned of the police attention that may very well have you throw up your arms and get out of the scene.
Best of luck.
Very sensitive aren't we.
I never once made a mention about commodores yet two people felt the need to chip in about all the non individual ones.
MissR34 do whatever you like, most people probably coudn't care less what you do with your car, so as lots of people have said. Do your own thing.
If you really want to stand out though put a periscope on it.
went for a hills run before, just missed a koala sitting in the middle of the road. must of been like a couple of cm's from missing it.
mmmmmm hks exhaust sound in the tunnels :D
Edited by Luke_ENR34
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
